For Sale - 2016 Hawk Four Wheel Camper
whitedog9
Roll over couch seating
Deluxe fabric cushions
Formica counter top
Dual Batteries w/Separator
Dual 10 Lb. propane tanks
160 Watt Solar Panel w/Charge Controller
Furnace system (Cabinet/Thermostat/Propane)
Mechanical camper jacks-4 corners
Dining Table
1 Fantastic Fan
Extra Roof Vent
Yakima tracks
Exterior lighting
Privacy Curtains
Gas Strut Roof Lifts
12 Volt Receptacles
Excellent condition
One of the pics shows a crescent size ding in the cabinet
$15000.00 will consider delivering depending---
We have had two of these-the main thing is that broadly speaking this Hawk will fit on a short bed pickup with a 6'5" bed if the bed side walls are 21" tall or less. The portion that sits in the bed is 23" =/- tall so if you have a 21" bed you will have 2" of clearance. The first one we bought was on 2012 Tundra and it had a bit over an inch of clearance-It was fine. If you have a bed with a bed depth that is higher than 22"-23" you will need to put something in the bed so the camper will be above the bed side rails by a couple inches. If the bed rails on your truck are 22" or higher you will need to put something on the bed to elevate the camper so it will be a couple inches above the top of the rails-easy breezy.
There is a ding on the cabinet ledge in front of the battery compartment, a couple tiny paint chips-great shape!
Thanks for your inquiry,
Reggie
509838
509827
509828
509829
509831
509832
509834
509835
509837
509840
whitedog9
I am in Athens, GA. Our mailing address is Winterville that borders Athens. Yes I can help with the install-generally speaking it’s not difficult. I have installed both of ours
Kc_trailhawk
