2017 Custom Built 4x4 Expedition Trailer
“The Beast”
Trailer:
-Trailer length is 165”
-Made from 2x4x1/8” tubular steel frame
-Upper structure is 1 1/2” tubular steel
-Rear 2” receiver (the receiver is welded directly to the hitch tubing that runs the full length of trailer)
-3500HD E-Z Lube suspension (same size lug pattern from a Toyota FJ, wheel hub width is 68”, Axle Less suspension with 12” brakes, Nev-R-Adjust electric brakes, 6 on 5 1/2” lug pattern)
-2 Custom Atwood 1000 lbs stabilizer jacks
-Lock N Roll expedition hitch
-Square tongue Jack
-Falken Wildpeak AT3 285/70R17 tires with Mickey Thompson Baja Lock rims
-LED trailer tail lights
-Two door entry with LED lighting
-Same wheel track as a Toyota FJ. Perfect for a Bronco, Jeep and Toyota
-14 gallon water tank onboard + 5 gal Jerry can
-All fasteners are stainless
Exterior:
-Driver’s side ARB 2500mm awning with optional side canvas and custom wind
skirt
-Rear LED flood light
-Driver’s side stainless steel pull out kitchen with drawer and sink
-2 Action Packer boxes with tie down straps
-Eco-Temp tankless water heater in lockable box
-Shower/toilet tent
-Hose bib
-14”h x 14 1/2”w x 14”t lockable aluminum storage box
-14”h x 141/2”w x 7” lockable recovery box with shovel
-Leveling blocks
-Large rear storage compartment with LED lighting
-One 4.25 lbs propane tank (for cooking)
-One 20 lbs propane tank for trailer
Interior:
-Fully insulated cabin with a Propex HS 2000 propane heater
-Full size custom CoolMax luxury gel foam mattress
-14x14 roof vent with fan
-Interior size is 45”h x 50”w x 75”l
-Two LED reading lights
-Two cup holders (not plastic)
-Roof webbing for cloths/jackets
- Two drawers and one shelf
- Carbon monoxide / smoke detector
- Extreme weather window insulated covers (not installed)
Electrical:
-Renogy 120 watt solar suitcase
-Two Trojan T-105 6 volt batteries
-12 volt system (210 amps total)
-Krueger 1500 watt inverter with remote I/O -10 amp GEN1 Genius battery charger
-7 way trailer plug
-12 volt Color TV
-Pioneer speakers enclosures
-Kenwood DVD /stereo
-Voltage meter
-USB ports
-12V port + standard round plug
-110 volt (inside of cabin)
-ARB plug 12 v outlet in storage compartment and one other located in back of trailer
-Renogy 120 watt suitcase solar panel with solar extension cable
Mlsc:
-Fresh water hose
-Port a Potty
-7 gallon kitchen gray water bucket with screen
Located in CA
