EastwoodSpaceCowboy
USA Made "Best in Class" go anywhere trailer for sale. I am very sad that we have to put our baby up for sale. It's given my family some of the best memories of our lives, in some of the most remote places in North America. But we started a business and we have to let her go.
We are asking $39,500.
Below is more detail, but in summary, the main add ons that we love are: upgraded Icon suspension, 2 mounted RotoPax gas cans, refrigerator slide, premium wheels and tires, solar charger, shower with 10 gallons of hot water, water filter, double rear stabilizers, batwing awning, 23 Zero walkabout tent with extra annex rooms, extra proprane tank for our Weber BBQ, fishing tubes, hot water,.
DETAILS:
1. WELDED 2 X 3 GALVANIZED TUBE STEEL CHASSIS WITH 11 GAUGE ALUMINUM FLOOR SYSTEM.
2. 3,500 LB RATED TIMBREN AXLELESS SUSPENSION.
3. FRONT AND REAR 2 INCH RECEIVER HITCHES.
4. EXPEDITION ALUMINUM SKIN AND BOX KIT INCLUDING FRONT, SIDES, VALANCES, DOORS, NOSE BOX, SIDE BOXES, AND TURTLE TAILGATE EMBLEM.
5. INCLUDES PARTNER STEEL STAINLESS STOVE WITH DUAL 10,000 BTU 18" BURNERS, LID, AND ADJUSTABLE WIND GUARDS, DUAL PRESSURE PROPANE SYSTEM, DOMETIC DEEP WELL STAINLESS STEEL SINK AND FAUCET WITH TEMPERED GLASS LID PREP SURFACE.
6. SINGLE BATTERY ELECTRICAL SYSTEM: TXL 125° C AUTOMOTIVE WIRING, BLUE SEA MARINE-GRADE COMPONENTS, SINGLE TROJAN GROUP 31 AGM DEEP CYCLE BATTERY, BATTERY BOX, BLUE SEA 6 CIRCUIT FUSE BLOCK, BLUE SEA SINGLE BATTERY DISCONNECT SWITCH, 6 AMP SINGLE BANK BATTERY CHARGER (SHORE POWER)
7. INTERIOR SIDEBOX MOUNTED CONTROL PANEL WITH BLUE SEA 8 CIRCUIT BREAKER PANEL, BATTERY POWER DISCONNECT, 2.1A USB CHARGE PORT, 12V SOCKET, OLED VOLTMETER, AND WATER HEATER SWITCH.
8. 4 EXTERIOR FLOOD LIGHTS, 4 STORAGE BOX LIGHTS, 1 MAIN STORAGE AREA LIGHT, 1 NOSE BOX LIGHT, 1 UTILITY AREA LIGHT, 1 CONTROL PANEL LIGHT, 3 UNDERCARRIAGE GREEN "TURTLE" CONVENIENCE LIGHTS
9. INCLUDES CHARGE LINE, BRAKE CONTROLLER LINE, RUNNING LIGHTS, SIGNAL LIGHTS, AND REVERSE LIGHTS
10. 4 RAIL CARGO/RTT POWDER COATED STEEL RACK
11. 18" X 36" STAINLESS STEEL PREP TABLE MOUNTED ON TAILGATE SWING OUT AND 16" X 25" STAINLESS STEEL PREP TABLE MOUNTED ON KITCHEN DOOR
12. 42 GALLON, FOOD GRADE, BPA FREE, WATER TANK WITH EXTERNAL, LOCKABLE FILL DOOR (VENTED)
13. 12V ON DEMAND WATER PUMP 3 GPM, 55 PSI, SELF PRIMING
14. ATWOOD 6 GALLON DIRECT SPARK IGNITION WATER HEATER
15. LOCKABLE EXTERIOR USE SHOWER WITH DEDICATED VALVE CONTROL, 5' PVC HOSE, AND SHOWERHEAD
16. 11 LB PANCAKE TYPE TANK FOR PRIMARY ON-BOARD SYSTEMS (DRIVER'S SIDE)
17. (2) 16 INCH STEEL WHEELS WITH ALL-TERRAIN 265/75R16 TIRES
18. *SWING OUT TAILGATE WITH FLIP-DOWN TABLE, SPARE TIRE MOUNT, AND ROTOPAX MOUNT. MOUNTED ON IDLER HUB ASSEMBLY FOR AXLE SPARE.
19. 2,000 LB SWING AWAY TONGUE JACK
20. TRAILER BREAK-AWAY BRAKE ACTIVATION SWITCH, LED YELLOW AND RED SIDE MARKER LIGHTS. LED BRAKE LIGHTS, SIGNAL LIGHTS, AND RUNNING LIGHTS. INTEGRATED REVERSE LIGHTS. ADJUSTABLE REAR STABILIZER (REQUIRED FOR DISCONNECTED HITCH USE). DUAL TOWING SAFETY CHAINS.
21. STANDARD COLOR POWDER COATING (***STEEL/ BLACK **)
22. MAX COUPLER ARTICULATING HITCH (6,000 LB RATING) 2 INCH DROP BALL MOUNT CURT EXTENDED 45270
23. GXL 125° C AUTOMOTIVE WIRING, BLUE SEA MARINE- GRADE COMPONENTS, DUAL TROJAN GROUP 31 AGM DEEP CYCLE BATTERIES FOR A COMBINED 210 AMP- HOURS OF POWER, BATTERY BOXES, BLUE SEA 6 CIRCUIT FUSE BLOCK, BLUE SEA DUAL BATTERY DISCONNECT SWITCH, 6 AMP HEAVY DUTY BATTERY CHARGER (SHORE POWER).
24. 1000 WATT PURE SINE WAVE INVERTER WITH BLUE SEA 150 AMP BREAKER
25. REDARC 12v Charger
26. XANTREX SOC MONITOR SYSTEM
27. ADDITIONAL CHARGE PORT (DRIVER KITCHEN, MAIN BOX, PASS SIDE BOX)
28. 4 RAIL CARGO/RTT POWDER COATED STEEL RACK WITH STORAGE AREA FOR 30" WIDE PICNIC TABLES, CHAIRS, ETC WITH SINGLE REAR DOOR MOUNTED ON ROOF RACK ASSEMBLY
29. TURTLEBACK EXCLUSIVE WITH ICON VEHICLE SUSPENSIONS DESIGNED RESERVOIR SHOCKS, CUSTOM WOUND DUAL RATE PROGRESSIVE SPRINGS AND DAYSTAR PRODUCTS KEVLAR BUSHINGS. ONLY AVAILABLE ON TURTLEBACK TRAILERS
30. UPGRADES INTERIOR PANELS AND KITCHEN TO MARINE GRADE HIGH DENSITY POLYMER MATERIAL. WATERPROOF AND UV STABLE THIS MATERIAL WILL LAST A LIFETIME.
31. ACCESSORY TANK WITH STAINLESS BRACKET KIT.
32. EXPEDITION SPARE TIRE.
33. BATWING AWNING KIT WITH ADJUSTABLE STAINLESS BRACKETS.
34. BLACK POWDER COATED TREAD PLATE ON TOP OF SIDE STORAGE BOXES.
35. PEREGRINE QUICK PITCH SHOWER ENCLOSURE - 230QPSE; TURTLEBACK SWING OUT MOUNT FOR SHOWER.
36. WALKABOUT 72 WITH ANNEX 82".
37. ICON 17 x 8.50 5x150 5.750 3100 LBS 30 LBS TITANIUM WHEELS.
38. TOYO TIRE M/T TIRES 35 X12.50 R17 LT.
39. CLEAR COAT POWDER COATING FOR METALLIC COLOR OR ADDED DURABILITY & ENHANCED FINISH STEEL.
40. WATER PURIFIER FOR MAIN TANK.
41. DUAL REAR STABLIZERS FOR EXTRA SUPPORT WHEN TENT IS OPEN.
DETAILS:
