For Sale: Rare - Dakar Inspired 2009 BMW G450X, Tuned. Lots of Extras. $5000 Price Dropped - NYC
SoldierNYC
For Sale Dakar Inspired 2009 BMW G450X.
Extremely fast, open terrain Enduro bike, street legal in all 50 states. Has a massive 52 hp at the wheels, roughly 10% more at the crank. If you want to go fast this is the bike for you. With 15 – 48 setup, currently at 14-48, you can achieve 100mph on packed or sandy terrain.
Owned this bike for more than 5 years. Now have to sell it, because I started doing a lot more hard enduro / single track riding, and this bike a bit much for that. Bought a smaller 250cc which is perfect for that, and no longer really use G450X.
Bike is in perfect running condition. Has 153.1hr / 4968 miles. Engine running perfectly, good clutch, great all around mechanically. There is a video in a link with a cold start of the bike. Bike has lot of extras, and a big list of oem parts no longer installed, see the list below.
Here is a large list of parts that have been added to this bike:
Mechanical and Control:
· Power Commander V with HEX Code Map ( ~52HP at the wheel, roughly +10% at the crank)
· Arrow Titanium Exhaust (As quiet as stock exhaust)
· Twin Air Reusable Air Filter
· Custom Overflow Cooling reservoir
· Zeta 2.0 Clutch assembly
· G2 Throttle Tamer (to be able to control all that power to the ground)
· Almost new DID X-Ring Chain and Sprockets (14 – 48)
· Zip-ty Racing Magnetic Oil Filter Cover (96lb pull magnet)
· Addon Safari Rear Tank 2 Gallons (4.2 Gallons Total. Can be mounted in 10 min by removing one body panel, 4 bolts to fuel tank and already prepped fuel line, see pics. Depending on riding style can go 200miles +)
· Tires
* Rear – Motoz Tractionator Enduro S/T DOT Approved - 60% New
* Front – Dunlop Geomax AT81 – Non DOT Approved - 90% New
(If you need Front DOT approved tire I have a used Continental TKC80 I can give you, just let me know in advance)
Body:
· Speedbrain / Blackbird Rally Racing Seat
· Barkbusters VPS Handguard Kit
· BMW Motorrad Aluminum Skid Plate
· KTM Military Folding Mirror Left (To keep street legal requirements)
· PowerMadd Trail Star Mirrors Foldable for Single Track riding (Left and Right)
· Reinforced Rear Fender with Toolbag capable of carrying up to 10 pounds of tools, even through rough terrain. (Usually carry set of tire irons, full set of tools, 21inch tube, hand pump, kickstand and some more)
· New Progrip 788 Grips
· Kriega Fork Seal Covers
· Moose Racing Pull Handle (Rear)
Electrical:
· Shorai Lithium Ion Battery
· All LED Lighting
* Cyclops Adventure LED Headlight Bulb 4800 Lumen
* Additional Marker / Brake Light (UFO Plastics / DOT approved)
* LED Turn Signals with LED Relay
· Powered Ram Mount / Garmin assembly for Garmin Montana 600 Series
· SAE Battery Connector for Accessories
Extra Stuff Included with the Bike.
· Full Dealer DVD Repair Manual, if you need to fix something outside normal Maintenance listed in user manual. ( This DVD runs on PC only, Also including SD Card with ISO image for this program and a program to mount ISO)
· Original User Manual (Paper), also will include digital version on SD Card
· Power Commander Installation Instructions, will also include on SD Card, 0 Map and Hex Code Map running on the bike
· Original Toolbag with BMW Tools and some extra, will also include 21inch tube for rear toolbag
· Original Plastic Skid Plate
· Original OEM Exhaust
· Original OEM Mirror
· Original OEM Throttle Tube
· BMW Lower Chain Guard, Brand New
· Original OEM Seat with bracket
· BMW Mini Rack, requires OEM Seat
· Original OEM Clutch Lever
· All Balls Racing Set of Wheel Bearings, Good for both Front or Back
· Set of OEM Plastic (5 pieces, Rear Fender, 2 x Left Front, Rear Left and Right Number Plate plastic, missing Right Front)
· OEM Front Sprockets (15 and 13 teeth)
· Extra bolts, purchased by first owner from BMW, never had to use them
· Old Broken Kick Stand, Broken Ear, can be fixed, but I used to lean it on trees on the trail or you also get a side attached kickstand packed in toolbag, easy to use.
· 2L of Motul Mineral Oil, and a good easy fill funnel
Some Downs and Damages
· Right Side plastic have been broken when I clipped the branch. Duck taped it together and it is ok, plastic as well as other parts for G450X still sold by BMW Motorrad. Last I check this plastic was $58, just never got around to purchase another piece.
· Also from the same branch I had slight headlight bracket damage, had to use good old cable tie, but it sits together firmly and I don’t see a reason to change that.
· Lastly, turn signal switch started to fall apart for unknown reason, also cable tie helped, solid and working.
· Bike has all around scratches from normal use
· Original kick stand is broken, can be fixed so you can have it as well, or use a standalone kickstand you will get with tooldbox
· Safari extra 2 Gallon tank was purchased used, already had black bedliner paint on it, I did plastic dip paint in white, that did not work so well as it started to scratch off and loose it’s color. You can easily rip plastic dip off. I wanted to use white bed liner paint on it since it seem to work way better and never got around to it.
More Pictures and Video Here:
https://drive.google.com/drive/folders/1CxLz3OmkXqfjRqQ1DHlsNAQUTd_jo91I?usp=sharing
Please PM me for any question. Bike is located around Brooklyn, NY area.
Thanks.
Roman.
iStan814
