2007 FORD F550 4x4 Custom LARIAT HAULER (46,650 original miles) with ALUMINUM - Financing avail R & B Auto Center 16020 Foothill, Fontana
1 owner ( custom build over $100,000)
Diesel
LEGENDARY 5R110 HEAVY DUTY TRANSMISSION
Leather
New Radial Tires
Custom Interior
5th Wheel Hitch
Loaded (every option avail… windows, locks, cruise, tilt
4X4 - 200" WB
Utility Bodyworks Custom Elite 84 Aluminum Haul Bed
*************46,650 original miles***************
50 gallon spare fuel added to 41 gal factory = 91 gal total diesel fuel
Thelma Drive-line Retarder
Reyco Granning Air Suspension
Custom Roper Leather
Carbon Fiber dash and consoles head & center
Pioneer AVIC-Z1 : rear seat TV monitor, Sat Radio
Electric fold down rear sleeper bed roper leather interior, Thelma driveline retarder
WESTERN HAULER MULTI PURPOSE BED includes: sprayed on bed liner, top of bed rails, mud flaps, aluminum fenders, complete trailer hookup, spare tire, tool boxes, headache rack with lights, installed, undercoated, painted to match truck.
WINDOW TINT
RECOVER FACTORY SEATS - front & rear
CUSTOM BUCKET SEATS - power base cloth or like leather
REAR SOFA SEAT - power base cloth or like leather
RECOVER REAR FACTORY SEAT-LEATHER
6-WAY POWER SEAT BASE - DRIVER
6-WAY POWER SEAT BASE - PASSENGER
WOOD FLOOR CONSOLE WITH: high gloss-high performance finish
DRINK HOLDERS AND STORAGE
OVERHEAD WOOD CONSOLE: high gloss-high performance finish
CB RADIO - with weather channel
RADAR DETECTOR - with laser escort 8500
REAR SEAT ENTERTAINMENT SYSTEM
GAUGE PACKAGE - pyrometer & turbo boost
STEREO SYSTEM
EQUALIZER HITCH
REAR BUMPER HD BLACK
REAR ROLL PAN
MUDFLAPS, BRACKETS, WEIGHTS, ANTI-SAILS
BED SIDE PROTECTORS -
PAINTED HEADACHE RACK WITH LIGHTS
TAIL GATE RUBBER
RUBBER BED MAT
BED LINER
FIBERGLASS GROUND EFFECTS
RUNNING BOARDS
DIAMOND PLATE OR EXTRUDED ALUMINUM RUNNING BOARDS FRONT & REAR
STAINLESS STEEL RUNNING BOARDS FRONT & BACK
RUNNING BOARD LIGHTS
SUN VISOR
FRONT SPOILER
VENT SHADES
REAR CAB DEFLECTOR
HOOD PROTECTOR
BILLET GRILL
TOW HOOKS
CLEAR COAT
CUSTOM PAINT
ALUMINUM WHEELS - (4)
Rhino Liner Box tops
ALUMINUM AUXILIARY FUEL TANK
90 Gal W/TOOL BOX W/SWITCHING VALVE
Weight Spec’s
Fifth Wheel Hitch - Max Tongue Wt. (lbs) 2490
Fifth Wheel Hitch - Max Trailer Wt. (lbs) 24,600
Wt Distributing Hitch - Max Tongue Wt. (lbs) 1600
Wt Distributing Hitch - Max Trailer Wt. (lbs) 16,000
Lariat 4WD Crew Cab 200" WB 84" CA Lariat
Brakes
Brake Type Pwr
Brake ABS System (Second Line)
Disc - Front (Yes or ) Yes
Disc - Rear (Yes or ) Yes
Front Brake Rotor Diam x Thickness (in) 14.53 x 0.47
Rear Brake Rotor Diam x Thickness (in) 15.35 x 0.47
Brake ABS System 4-Wheel
Cooling System
Total Cooling System Capacity (qts) 26.4
Electrical
Maximum Alternator Watts - TBD -
Maximum Alternator Capacity (amps) 140
Maximum Alternator Watts 1725
Engine
Engine Oil Cooler
Engine Type Turbo Diesel V8
Displacement 6.0L/363
Fuel System DI
SAE Net Horsepower @ RPM 325 @ 3300
SAE Net Torque @ RPM 570 @ 2000
Exterior Dimensions
Wheelbase (in) 200.2
Length, Overall w/o rear bumper (in) 285.0
Width, Max w/o mirrors (in) 93.6
Height, Overall (in) 81.3
Overhang, Front (in) 37.2
Overhang, Rear w/o bumper (in) 47.6
Front Bumper to Back of Cab (in) 153.4
Cab to Axle (in) 84.0
Ground Clearance, Rear (in) 8.0
Cab to End of Frame (in) 155.6
Ground Clearance, Front (in) - TBD -
Frame Width, Rear (in) 34.2
Ground to Top of Frame (in) 32.2
Ground to Top of Load Floor (in)
Frame
Frame Type Ladder
Fuel Tank
Aux Fuel Tank Location
Aux Fuel Tank Location Midship
Fuel Tank Capacity, Approx (gal) 40.0
Interior Dimensions
Second Head Room (in) 40.8
Passenger Capacity 5
Passenger Capacity 6
Second Hip Room (in) 67.3
Second Shoulder Room (in) 68.0
Second Leg Room (in) 41.7
Front Hip Room (in) 67.4
Front Shoulder Room (in) 68.0
Front Leg Room (in) 41.0
Front Head Room (in) 41.3
Mileage
Steering
Turning Diameter - Wall to Wall (ft) 59.5
Steering Ratio
1), On Center 17.8
Turning Diameter - Curb to Curb (ft) 57.8
Steering Type Pwr
Steering Ratio
1), At Lock 18.0
Summary
Body Style Crew Cab
Vehicle Name Ford Super Duty F-550 DRW
Body Code 200" WB
Suspension
Spring Capacity - Front (lbs) 6500
Axle Ratio
1) - Rear 4.88
Shock Absorber Diameter - Front (mm) 35.1
Shock Absorber Diameter - Rear (mm) 35.1
Stabilizer Bar Diameter - Front (in) - TBD -
Stabilizer Bar Diameter - Rear (in) - TBD -
Suspension Type - Front Coil Spring
Axle Ratio
1) - Rear 5.38
Suspension Type - Rear Multi-Leaf With Air Bags
Axle Ratio
1) - Front 4.88
Axle Capacity - Rear (lbs) 13,660
Axle Type - Rear Full-Floating
Axle Type - Front Monobeam
Spring Capacity - Rear (lbs) 13,660
Spring Capacity - Front (lbs) 6000
Tires
Rear Tire Order Code T9C
Front Tire Order Code TBV
Front Tire Order Code T9B
Front Tire Order Code T9C
Front Tire Order Code T91
Rear Tire Order Code TBV
Rear Tire Order Code T9B
Rear Tire Order Code T91
Spare Tire Order Code 512
Front Tire Size 225/70R19.5G
Front Tire Size 225/70R19.5F
Rear Tire Size 225/70R19.5G
Rear Tire Size 225/70R19.5F
Spare Tire Size 225/70R19.5G
Spare Tire Size 225/70R19.5F
Spare Tire Size
Front Tire Capacity (lbs) 3415
Rear Tire Capacity (lbs) 3415
Spare Tire Capacity (lbs) 3415
Revolutions/Mile @ 45 mph - Front 646
Revolutions/Mile @ 45 mph - Front 654
Revolutions/Mile @ 45 mph - Front 653
Revolutions/Mile @ 45 mph - Rear 646
Revolutions/Mile @ 45 mph - Rear 654
Revolutions/Mile @ 45 mph - Rear 653
Revolutions/Mile @ 45 mph - Spare 646
Revolutions/Mile @ 45 mph - Spare 654
Revolutions/Mile @ 45 mph - Spare 653
Trailering
Transmission
Transfer Case Gear Ratio
1), High 1.00
Drivetrain 4-Wheel Drive
Trans Description Cont. Automatic w/OD
Gross Axle Wt Rating - Front (lbs) 6500
28,000
Curb Weight - Front (lbs) 4849
Curb Weight - Rear (lbs) 3042
Front Wheel Size (in) 19.5 x 6
Rear Wheel Size (in) 19.5 x 6
Spare Wheel Size (in) 19.5 x 6
Front Wheel Material Aluminum
Rear Wheel Material Aluminum
Dually Insinde Steel
Spare Wheel Material Steel
AIR RIDE WITH ON BOARD COMPRESSOR and GAUGE
This is a very rare Truck, especially in the 4x4 / 200” WB configuration.
It is a “luxury ride” for the Glamis or Overlanding Expeditions OFF Road traveler in mind.
(No more getting stuck when you are towing)
Just fully serviced and detailed
Here’s a link to more images for the F550 4x4 Heavy Hauler
www.racingjunk.com
Diesel
Leather
New Radial Tires
Custom Interior
5th Wheel Hitch
4X4 - 200" WB
WINDOW TINT
STEREO SYSTEM
EQUALIZER HITCH
REAR ROLL PAN
TAIL GATE RUBBER
RUBBER BED MAT
BED LINER
RUNNING BOARDS
SUN VISOR
FRONT SPOILER
VENT SHADES
REAR CAB DEFLECTOR
HOOD PROTECTOR
BILLET GRILL
TOW HOOKS
CLEAR COAT
CUSTOM PAINT
Weight Spec’s
Brakes
Brake Type Pwr
Cooling System
Electrical
Engine
Engine Oil Cooler
Fuel System DI
Exterior Dimensions
Frame
Frame Type Ladder
Fuel Tank
Interior Dimensions
Mileage
Steering
Steering Ratio
Steering Type Pwr
Steering Ratio
Summary
Body Style Crew Cab
Body Code 200" WB
Suspension
Axle Ratio
Axle Ratio
Axle Ratio
Tires
Spare Tire Size
Trailering
Transmission
28,000
Race Cars, Parts, Trailers & Engines for Sale | RacingJunk Classifieds
