Ford Van/Ambulance/RV aft fuel tank 35 gallons
hobietony
$200. Aft fuel tank from a 1997 Ford E350 cutaway ambulance chassis. Approx 35 gallons, approx 14x30x21. (I replaced with a 55 gallon tank) All straps and mounting hardware included. Tank was used for Diesel. Gasoline pickup and sending unit included, but tank can be used for diesel or gas. In Tucson, local pickup is way preferred, it will be pricy and a bit of a hassle to to freight ship this, but I'll ship for actual shipping costs. I can work out something transporting it myself within a 'reasonable' radius if that will help. I check text much more frequently - five2zero, 95five, 2seven6nine. Tony. Thanks!
I have the 350 extended model, I wonder if it would fit behind the rear axle temporarily just to get it back home to Northern, CA.... just happen to be in Tucson visiting! Will check this tomorrow and text. In the meantime I will do some more investigating. Thanks.
hobietony
Hmmm, you might find a crossmember in the way, or a spare tire - although I see that this was from Sunday, maybe out of town already?
Yeah, sorry, no time to investigate to decide... but bTW, the extended has a huge area between in front of the spare tire.... although I have not checked out the possible cross member issue. Yes, now over on the coast but if I have any info to add I will!
Babbert
