Camburg Engineering Ford E 250/350 Baja Performance Long Travel 2WD Front Suspension System
http://camburg.com/all-products/e-series-van/ford-eseries-van-baja-performance-kit/
Parts include:
Modified Ibeams, custom extended radius arms with uniball pivots, long travel coil springs, 2 pair custom valved Fox 2.0 remote reservoir shocks front, 2.0 non-reservoir rear, limit straps, dropped pitman arm.
I had this system on my van for +/5 years. The system raises the van about 3.5” and provides a full 10+ inches of plush, useable travel. When combined with a good set of progressive rear springs (Deaver or equivalent) you will be amazed what a 2WD van is capable of. This system new retails for $3450 and requires leaving your rig with Camburg. With these used parts it should be simple driveway swap on 97-04 E250/350. Possibly other years.
Components have seen off road use and could use a good prep and paint. No rotors, calipers or tie rods. McQuay-Norris ball joints have maybe 20kmi and are tight.
$1750. Parts are in the San Francisco bay area. Would consider shipping if you arrange it. Forklift and pallet available. Thanks for looking.
Parts include:
