Foxwing...custom mount
Copasspupil
Since they really dont sell a mount for it, any ideas for those that have made one or thought of doing it? My RTT frame is set with 1 3/4” DOM tubing and I have to either use a 15” section of the same DOM tubing welded to a piece of flat stock. OR. I use 2x2 square tubing and do the same idea. I need to place the awning about 6” past the curve so it doesn’t not interfere the lights.
Anybody have an idea one way or another on this?
What about modifying the factory brackets? Cut off the section on the truck side and weld on a new truck side mount that is radiused to the 1 ¾” DOM.
That might work. I could take a section of scrap DOM material weld it to the frame with just an extension on the end then clamp it that way. I’ll go check. Thanks.
OchoSolo
