Mundo4x4Casa
West slope, N. Ser. Nev.
In my later years, I've continued my life long penchant for not leaving 'good enough' alone when it comes to four wheel drives. I did my first springs-over-axle in 1965 on a 1949 Willys Ute Wagon, during an era when there were few willing to try it or even knew what it was. Those pioneer days are long gone. Here it is by 1968:
Subsequently, I completed a lot of SOA's on leaf sprung 4WD's of all stripes and learned a lot about suspensions along the way. Three of my victims:
My hard core jeeping days are over, but I still maintain a Dodge pickup with stuff and a hard side Lance camper. This rig is now my focus. Here it is on the Mojave Road:
And a current config:
Background: I would like to install a long arm 4-link kit to the front axle to increase the suspension travel and solve my current caster woes. For more background, view this post:
http://truckcamperadventure.com/2017/01/extreme-truck-camper-drivetrain-build/
This would include softer, incremental rate lift coils with heavy shocking. Currently I have a 3 inch 'puck' lift on the short arm front axle. The reason for a quest for more suspension travel is to transfer less torque to the frame, and subsequently less frame twisting. I suffer very little frame twisting now with a short bed, hydro formed frame of the era, but I want even less frame twisting. The rear axle would remain as it is now with little suspension travel when loaded. What you are looking at is the factory camper package with one thicker upper secondary; an anti sway bar; two added upper secondaries from a one ton; a 3 inch lift spring; and Stable Loads to successfully haul my 2650 pound load off road. My idea is to solidify the rear and free up the front effectively pivoting on the rear axle.
With all this in mind, my questions are:
1. How would softer, longer travel coil springs in front effect the weight transfer when hard braking?
2. Are there other down sides I'm not seeing?
3. What, in your opinion, are any other unintended consequences to this 'soft front/hard rear' plan?
I hope this becomes a physics discussion and divulging of experience.
Even if you have NO experience with this, give me your best shot.
regards, as always, jefe (aka: jeff reynolds)
