Freightliner 4x4 Crew Cab - automatic Trans - 14 ft insulated Box + sleeper
Here is link to Video of Freightliner:
2008 Freightliner 4x4 Flatbed with quick mount 14 ft Box (box can be removed in 30 minutes)
VIN - 1FVDCXBS48HZ75358
Automatic Trans
4 door
2 GCVW is 66000lbs
Crew Cab with Sleeper-11ft deck- cummins 8.3 -79,000 miles
14 ft Insulated Morgan Box with quick attachments ( can be removed in minutes)
Cummins ISC 8.3 diesel Motor – Pre Def ( Link: https://www.4btengines.com/isc-8-3-engine-specs-history/ )
Allison 3500 Automatic Transmission
Factory 4x4
Air Brakes
Air Ride suspension and air ride Cab
240 inch wheel base
11 ft flatbed with Gooseneck Ball
124 Cab to axle and Sleeper to axle measurements
Oil Capacity 6.3 Gallons
Governor Speed Hydra mechanical or PSG (2200-2500 RPM)
Horsepower 240 - 400 hp @ 2500 rpm 179 -298 kW
Torque 670 - 1,075 lb-ft
Like New - Heavy Duty Tires on Aluminum Alcoa 22.5 Wheels
Truck currently has 4 bucket seats plus the sleeper.
It’s very easy to drive and very low miles
Just Serviced and replaced all Oils Transfer case/Transmission/front and rear differential’s, Brakes , bearings, fluids
- Meritor Front and rear Diff’s ( Link: https://www.meritor.com/products/axles/ )
- Meritor Transfer case
- Air Brakes
- Free Wheeling Hubs
- Super Single rear
- Shift on “Fly” under 10 mph-
- New Wiper blades
- Quad Bucket Seating
- LED Brake lights
- 46” inch Sleeper
- Air conditioning
- Kenwood Stereo
- Backup Camera
- Alarm
- Heated Mirrors
- Electric Locks
- Electric Windows
- Recently replaced Tires
- New Carpet
- Sleeper
- Undercoating
- LED LIGHTS exterior
- Aluminum wheels polished
- Trailer Brake
- New Custom Exhaust
- 4x4
- Rear Deck is 10’8” l x 8’ w
- Clear clean Title
- GVWR dry 15,000lbs
- Tires 90%
- Wheel Base center to center= 20ft 2 inches
- Overall Length 30ft
- Height 9ft 6inches
: GCVW is 66000 lbs
The truck has a 19,500 lbs Gross Vehicle Weight Rating (GVWR), and a towing capacity of 30,000 lbs
Measurments:
76 1/2 inches from back of sleeper to the axle 128 inches from back of cab to the axle
Truck is in Southern California – I will pay for Airfare to/from Ontario Airport , Ontario Ca
Financing is available
$85,000. usd
This 4x4 crew cab is the only one for sale in the US
financing
(Rates start at 4.5% for excellent credit. If the credit is 700+ they may qualify for a first payment only option as opposed to 10-20% down.. Here are the approximate numbers: Client expectations Homeowners generally receive better interest rate .
10-15% down payment required
Excellent credit scenarios 700+ may qualify for first payment only option Interest rate estimates Great credit 4.5%-7% Lower tier 7%-12% Subprime 12%+ | Bruised credit
\Subprime credit credit score : 550-580 May be subject to 20-30% down payment
RB Auto and Truck Center
Est. 1986
16020 Foothill Blvd.
Fontana, CA 92335
O: 909-829-1140 - Dustin
C: 909-478-4791 - Bob
Certified Master Dealer- NIADA
AAA Certified Service Provider
A+ Rating with BBB
Automatic Trans
4 door
2 GCVW is 66000lbs
Factory 4x4
Air Brakes
240 inch wheel base
- Air Brakes
- Super Single rear
- New Wiper blades
- LED Brake lights
- 46” inch Sleeper
- Air conditioning
- Kenwood Stereo
- Backup Camera
- Alarm
- Heated Mirrors
- Electric Locks
- Electric Windows
- New Carpet
- Sleeper
- Undercoating
- Trailer Brake
- 4x4
- Clear clean Title
- Tires 90%
: GCVW is 66000 lbs
Measurments:
$85,000. usd
financing
Est. 1986
Fontana, CA 92335
A+ Rating with BBB
