Freightliner 4x4 Crew cab automatic transmission - sleeper - 14 ft quick mount box - 11ft flatbed $89,usd
Bob De Lozier
Freightliner 4x4 – low miles Flatbed with Box
2008 Freightliner 4x4 Flatbed with quick mount 14 ft Box
Automatic Trans
4 door
2 GCVW is 66000lbs
Crew Cab with Sleeper-11ft deck- cummins 8.3 -79,000 miles
14 ft Insulated Morgan Box with quick attachments ( can be removed in minutes)
Pre DEF Cummins ISC 8.3 diesel Motor
Allison 3500 Automatic Transmission
4x4
Air Brakes
Air Ride suspension and air ride Cab
240 inch wheel base
11 ft flatbed with Gooseneck Ball
124 Cab to axle and 6" Sleeper to axle measurements
Oil Capacity 6.3 Gallons
Governor Speed Hydramechanical or PSG (2200-2500 RPM)
Horsepower 240 - 400 hp @ 2500 rpm 179 -298 kW
Torque 670 - 1,075 lb-ft
Like New 42" Heavy Duty Tires on Aluminum Alcoa 22.5 Wheels
Truck currently has 4 seats plus the sleeper.
It’s very easy to drive and very low miles
*Just Serviced and replaced all Oils Transfer case/Transmission/front and rear differential’s, Brakes , bearings, fluids
-Super Single rear
-New Wiper blades
-Quad Bucket Seating
-LED Brake lights
-46” inch Sleeper
-Air conditioning
-Kenwood Stereo
-Backup Camera
-Alarm
-Heated Mirrors
-Electric Locks
-Electric Windows
-Recently replaced Tires
-New Carpet
-Sleeper
-Undercoating
-LED LIGHTS exterior
-Aluminum wheels polished
-Trailer Brake
-New Custom Exhaust
- 4x4
-Rear Deck is 10’8” l x 8’ w
-Clear clean Title
* GVWR dry 15,000lbs
-Tires 90%
-Wheel Base center to center= 20ft 2 inches
-Overall Length 30ft
-Height 9ft 6inches
: GCVW is 66000 lbs
The truck has a 19,500 lbs Gross Vehicle Weight Rating (GVWR), and a towing capacity of 30,000 lbs.
Truck is in Southern California
Financing is available
$89,000.
Bob 909 478 4791
Bob
C: 909-478-4791
