Freightliner 4x4 Crew Cab w/ Sleeper / automatic / Flat Bed / quick connect ft insulated Box (still avail)
bdelozier
2008 Freightliner 4x4 Automatic Trans 4 door
2 GCVW is 66000lbs
Crew Cab with Sleeper-11ft deck- cummins 8.3 -79,000 miles
( it’s the only one available anywhere)
Pre DEF Cummins ISC 8.3 diesel Motor with a new turbo
Allison 3500 Automatic Transmission
Four Wheel Drive
Air Brakes
Air Ride suspension and air ride Cab
240 inch wheel base
11 ft flatbed with Gooseneck Ball
124 Cab to axle and 6" Sleeper to axle measurements
Oil Capacity6.3 Gallons
Governor SpeedHydramechanical or PSG (2200-2500 RPM)
Horsepower240 - 400 hp @ 2500 rpm 179 -298 kW
Torque670 - 1,075 lb-ft
Like New 42" Heavy Duty, aggressive, Tires on Aluminum Alcoa 22.5 Wheels
Truck currently has 4 seats plus the sleeper. More seats could be added if needed
It’s very easy to drive and very low miles
*Just Serviced and replaced all Oils Transfer case/Transmission/front and rear differential’s, Brakes , bearings, fluids
-Super Single rear
-New Wiper blades
-Quad Bucket Seating
-LED Brake lights
-46” inch Sleeper
-Air conditioning
-Kenwood Stereo
-Backup Camera
-Alarm
-Heated Mirrors
-Electric Locks
-Electric Windows
-Recently replaced Tires
-New Carpet
-Sleeper
-Undercoating
-LED LIGHTS exterior
-Aluminum wheels polished
-Trailer Brake
-New Custom Exhaust
- 4x4
-Rear Deck is 10’8” l x 8’ w
-Clear clean Title
* GVWR dry 15,000lbs
-Tires 90%
-Wheel Base center to center= 20ft 2 inches
-Overall Length 30ft
-Height 9ft 6inches
: GCVW is 66000 lbs
The truck has a 19,500 lbs Gross Vehicle Weight Rating (GVWR), and a towing capacity of about 30,000 lbs.Jun 1, 2019
Financing is available
$85,000.
Below is Link to more images
https://www.racingjunk.com/Tow-Vehi...er-4x4-Crew-Cab-with-Automatic-Trans-A-C.html
woodsdoc
It's about 10 times overkill for what I really need and not at all practical for where I usually drive, but I was just imagining it with something like 47" offroad tires and my Hawk flatbed on the back just for the sheer absurdity of the overkill. It isn't that much more expensive than the trucks I have been looking at though, just a bit harder to park in the driveway.
It does like like a unique build though and best of luck with the sale.
