Front cam and crank seal diameters?
DirtyDC05
I'm trying to get all the tools to complete my timing belt and front seal job done. I'm waiting for my parts to be shipped so I'm looking for a seal installer kit that will fit these seals. Can someone give me the seal diameters for front cam seals and crank seal? This is for the gen 2.5, 3.5l
Thanks
Aaron
jeep-N-montero
If you look up the individual parts on rock auto they usually give detailed specs on every part, not sure on seals but it's worth a shot.
nckwltn
check the part number on amazon too... sometimes they have the sizes listed.
Also, think about PVC for installation. I picked up a PVC union to install the pinion gear seal on the rear diff. Worked like a charm
DirtyDC05
I thought about PVC but I ended up ordering a installer/puller kit on amazon. I found out its 50mm od and 35mm I'd on the cam seal. Hope the kit will work. Thanks for the replies.
Clemtiger84
