Howski
I've had a clicking noise from the front end that has sprung up. It occured once before for a short period of time but went away after I greased the hell out of the u-joints on my front driveshaft. No looseness in the driveshaft so the u-joints seem to be fine. I grease them on every oil change and atleast once between every oil change. The noise seems to be coming from the front and only occurs under acceleration. If the truck is coasting or is kept at a constant speed there is no noise at all. It sounds similar to when my rear locker clicks although it is MUCH MUCH quieter. Any ideas on what it could be?
