SSF556
SE Expedition Society
2008 WK with 85,000 miles
OME HD Lift
Pavement driving, 2-3 hours of driving paved country roads, high ambient air temp 85+...no offroad. Clunk is not there at the start of the trip, but by the end the clunk is present. I do not get the clunk when I do rapid side to side movements of the steering wheel. I do not get the clunk when doing hard braking or accelerating. Clunk is at slower speed generally, but I have heard it at highway speed when you hit a pot hole or bridge joint. No excessive movement in the steering wheel or change in handling character. I rotate tires every 5,000 miles and I have gotten great tire wear across all 4 tires...nothing that indicates suspension or steering issue.
- 15,000 miles on OME shocks/springs
- Stock OEM CV axles...never had an grease leak
- Aftermarket UCA with greasable ball joints installed 5,000 miles ago...I greased them after I got the first clunk 2 months ago
- New greasable tie rod ends installed 15,000 miles ago....greased as well after I got the first clunk 2 months ago.
When the clunk first happened I thought something was loose in the suspension....went through and tightened everything that can be tightened. Nothing was loose.
Given that it is at the end of the driving cycle not the start and high ambient heat I was thinking the following....
1) Can a worn CV axle cause the clunk noise when hitting bumps?....I was hoping to get to at least 100K on the OEM axles
2) Could heat buildup in the front shocks cause the clunk? Again this is country road pavement...no continuos corrugation, no trail driving.
3) Could worn wheel bearings cause the clunk? With 32" tires they do wear quicker but again was hoping to get to the 100K mark on those as well.
The only reason I am thinking this is a friction or heat issue is that I do not get the noise all the time. If it was something that was not tight....upper shock mount it would be happening all the time.
Input appreciated....
OME HD Lift
