CAPT.HODGES
Price: $2000 firm
Selling a Front Runner truck bed drawer system consisting of the following:
- 6 Wolf Pack Drawer (including 6 boxes)
- 13.7gal Stainless Steel Water Tank (mounted to back of drawer system)
- Will also sell a Kamp-Rite Double Self Inflating Pad SIP391 for additonal $75 (has rainwater marks but otherwise fine)
Total Retail: $3650 before tax and freight
This system has supported our adventures from Canada to Baja in deserts, mountains, beaches, snow...you name it, we've camped in it. Water tank is great for showers or emergencies. I hate to let it go but have a travel trailer now for family adventures and won't use it as much. It secures with turnbuckles to tie-down points you can add to your bed (like D-rings). Comes with custom deck boards cut for a 2007 F250 short bed. Could be modified for a different truck as long as it's more narrow than this (which most of them are).
Pick up in Thousand Oaks, CA or we can negotiate delivery within a reasonable distance at buyers expense.
Details on drawer:
Materials used:
Aluminum - Accessory Channels & Sub Frame
Black powder coated steel - Frame
Carpet & Laminated plywood - Top Deck
Product Dimensions:
Overall Dimensions:
1252mm (49.3") L x 1083mm (42.6") W x 310mm (12.2") H
Drawer Inner Dimensions:
1197mm (47.1") L x 1031mm (40.6") W x 230mm (9.1") H
Drawer Unit Open Dimensions:
2163mm (85.2") L x 1083mm (42.6") W x 310mm (12.2") H
Weight:
67Kg (147.7lbs)
Load Rating:
113Kg (250lbs)
Details on water tank:
Water Tank:
Materials used:
304 Stainless Steel
Product Dimensions:
1065mm (41.9") W x 230mm (9.1") L x 285mm (11.2") H
Weight:
14.2kg (31.3lbs)
Water Pump:
Pump Specifications:
12 Volts
12.5 Liters per minute
35psi
Product Dimensions:
360mm (14.2") L x 135mm (5.3") W x 110mm (4.3") H
Weight:
2.13kg (4.7lbs)
Approximate Total Product Weight:
16.33kg (36lbs)
Details on drawer:
Materials used:
Product Dimensions:
Overall Dimensions:
Weight:
67Kg (147.7lbs)
Load Rating:
113Kg (250lbs)
Water Tank:
Materials used:
304 Stainless Steel
Product Dimensions:
Weight:
14.2kg (31.3lbs)
Water Pump:
12 Volts
35psi
Product Dimensions:
Weight:
2.13kg (4.7lbs)
16.33kg (36lbs)
