Frontrunner half-rack for 2 door Jeep JK Wrangler
I'm selling a brand new, still in the box, Frontrunner Outfitters half rack for a Jeep JK wrangler. I ended up going with a different rack to support a Rooftop Tent. I never even assembled it. This rack is normally $835 plus shipping. Frontrunner did say that you can purchase the additional pieces to make this a full rack for a difference of about $500, but this isn't required by any means.
Asking $500 + shipping costs.
PM me for more info.
jeep-wrangler-jk-roof-rack-2-door-half-cargo-rack-front-runner-slimline-ii-extreme-KRJW017T-1.jpg
jeep-wrangler-jk-roof-rack-2-door-half-cargo-rack-front-runner-slimline-ii-extreme-KRJW017T-3.jpg
jeep-wrangler-jk-roof-rack-2-door-half-cargo-rack-front-runner-slimline-ii-extreme-KRJW017T-5.jpg
Here is the info directly from Frontrunner:
This Slimline II rack kit contains the Slimline II tray (1425mm X 750mm), a Jeep Extreme Mounting System and a Wind Deflector.
This rugged, sophisticated, high performance, nearly indestructible mounting solution allows you to quickly remove the Freedom Panels and works with the hard top on or with no roof at all.
The JK Extreme mounting system bolts to the roll bar with middle and rear brackets. This unobtrusive, high performance, nearly indestructible mounting solution allows you to quickly remove the Freedom Panels and works with the hard top or with no roof at all. Freedom Panels can be quickly and easily removed with rack in place. The cargo weight is evenly distributed across the roll bars and body of the jeep, placing zero weight on the hard top itself.
Fits all 2010-Present Jeep Wrangler Unlimited 2-Door (JK).
Unlike most exoskeleton style roof rack mounting systems, the JK Extreme mount can be used with all aftermarket bumpers.
The all stainless steel, powder coated mounting system makes this mounting system virtually rust free.
All racks and accessories are built for off road durability with on road sophistication.
The Slimline II Tray is made entirely of lightweight, high tensile aluminum with a strength to weight ratio unmatched in the industry.
Powder coated aluminum will not rust.
ADDITIONAL SLATS can be installed to create a solid platform for sleeping or sitting.
Add the optional EXPEDITION RAILS to give your rack the classic style basket shape.
Over 25 Front Runner Rack accessories are available to easily and securely mount snow boards, bicycles, tents, kayaks, propane, tables, cases, logs, solar panels, fuel, and much more.
Add the optional FRONT RUNNER JEEP JK INTERIOR RACK and FRONT RUNNER JK CARGO SLIDE to stretch your packing and storage options even further.
The Slimline II is the most versatile and durable roof rack available.
The Slimline II Tray is fully modular. You can remove or add slats as needed and customize your roof rack to taste and need.
Clemtiger84
