FS: 06' Ford e450 Gear Hauler/Grip Truck
chadlanc
2006 Ford e450
6.8L V10
14ft Box
106,000 Miles
Mag-Hytec rear axle cover
Bilstein HD shocks all around
New-ish Tires probably 80%, 1 spare
AC Runs very cold
Modifications to box
- Subfloor, Walls, & Ceiling added with insulation all around
- Vinyl Floor tiling
- 300w Solar Panel
- Dual 4D AGM batteries
- Fan with remote control
- Industrial Storage Racks with carpet on decks
- Front desk with chalk board above
- Rear table with sink, foot pump, and 28 gallons of water
- LED Lighting
- Midnite Solar Kid Solar Controller
- DC to AC inverter 1000w
- Blue Sea Automatic Battery Charger (for charging box batteries from cars engine)
- Blue Sea fuses and electrical parts
- Isotherm Cruise 130 fridge/freezer 4.6cu ft, marine grade fridge
- Abus Puck lock on rear door
- Anti-slip tape on rear steps
Since its purchase a full system checkup and fluids change was done to bring it up to my standards just as precautionary standards.
- All belts replaced
- Engine oil flushed/changed
- K&N filter oil filter
- Cooling fluids flushed
- K&N air filter
- K&N fuel filter
- Transmission flushed/ filter changed/ fluids changed to Amsoil
- Rear axle flushed/ fluids changed to amsoil/ mag-hytec cover added
- Bilstein HD Shocks added all around
- 7 New tires
- Front alignment with bushings replaced
- Fire extinguisher in cab and in box.
- Rigid LED light Bar
$10,000 All Included
$8,000 Minus equipment
Located in Simi Valley, CA (LA Area)
chadlanc
The truck has been used on a film project to carry gear around in and charge camera batteries. The interior as you can see is very basic and can easily be torn out and replaced if you wanted. The whole interior is insulated and there is a fan for ventilation. The sink uses blue water containers from a sporting good store so that water was easy to get from the grocer store machines if needed. A marine foot pump is used for the sink and a bucket to empty the water. Industrial shelving can hold a ton of weight and was carpeted to keep things from sliding too much.
chadlanc
Clean seats with no rips, clean interior. Fire Extinguisher, DOT signals behind passenger seat.
Mechanic91
