2007 Toyota Tacoma Double Cab Short Bed Sport - Speedway Blue
21,000 miles!!
TRUCK OPTIONS:
-Power windows, locks, mirrors
- Cruise Control
- Tilt Wheel
- Roof Rack
- 400 watt inverter w/ 110v outlet in bed
DRIVE TRAIN:
- 4.0L V-6 stock, running Mobil 1 Synthetic oil
- 6spd. Manual transmission, running Amsoil Synthetic oil
- Inchworm Crawler w/ 2.28 gears
- Inchworm Lefty transfer case w/ 4.7 gears & twin sticks, Marlin 30 spline front and rear outputs
- single piece rear driveshaft with double cardigan joint and HD u-joints
- ARB rear locker
- all breathers extended up w/ filters
- Spal electric fan w/ variable speed controller, interior override switch
WHEELS/TIRES:
- Mickey Thompson Classic Lock 16x8
- Mickey Thompson MTZ’s 285/75R16
- matching spare
SUSPENSION:
Front:
- Fox 2.0 remote resi. Coilovers
- Total Chaos uniball UCA’s
- sway bar removed
Rear:
- Alcan AAL
- Bilstein 5125 shocks
- ATO shackle flip
- braided stainless extended brake lines
ARMOR:
- ATO front bumper, Smittybuilt XRC8 winch, Amsteel Blue synthetic line, interior controls
- 4xInnovations DOM weld on sliders w/ kick out
- Rear ATO wrap around high clearance bumper w/ hitch, flood lights, shackle mounts, hi lift notches, bedside protection, tire carrier, rear winch mount
- ATO front skid
- ATO Transmission Skid
- ATO gas tank skid
- One of a kind custom flat belly crossmember ans skids!!!!!!!
EXTERIOR MODS:
- Front, Middle, and Rear Halogen rock lights
- Black Billet Grill w/ hood scoop insert
- Black head light mod w/ Sylvania Silverstar Ultra bulbs
- custom exhaust crossover w/ Flowmaster 50 series truck/suv muffler
- led bed lights
- UWS chest toolbox
- ammo can on fender well
- Hi Lift mount on pass. Side bed
- Viair 450 constant duty compressor mounted in driver side bed cubby w/ 2.5 gal. tank under bed, air chuck inside bed
- Toyota rubber bed mat
- vent visors on all 4 doors
- 50% tint on front windows
- Sockmonkey Tacoma decals
- Sockmonkey Hood Scoop Blackout
- Safari Snorkel
INTERIOR MODS:
- Weather Tech floor liners front and rear
- Toyota door sill guards
- blue led floor accent lighting tied in with dome light
- 2 110v outlets on rear of center console tied into stock inverter w/ 400 watt anytime mod
- 12v cigarette plug and 5v USB plug in rear of center console always on
- Mag light holder at drivers side back door
- Uniden 510 cb mounted in center console
- blue backlight gauge cluster w/ white needles
- blue backlight on window switch, steering wheel controls, clock
- Aeroforce Interceptor gauge and Air pressure gauge mounted in A-pillar gauge pod
- Carling switches on left side of dash and overhead console
- 2 Painless Wiring fuse blocks mounted under hood w/ Painless Wiring relay bank
- custom cupholer area to accommodate twin sticks from tcase
AUDIO:
- Kenwood DDX 7019 in dash DVD player w/ 7” touch screen, xm satellite radio hooked up, and ipod audio/video connector in center console
- Rear backup camera
- Pioneer Premier TS-C720PRS front components
- Pioneer Premier TS-D601P rear 2 way speakers
- Eclipse XA4000 4 channel amp
- 10" Infinity self powered sub
- Mr. Marv speaker adapters used on the doors
- Elemental Design sound deadening on all doors and rear cab wall
Truck has the normal light pin striping from trail riding. A few heavier scratches here and there but most would buff out. There is one small dent on the drivers side bedside just behind the gas door.
This truck goes like no other on the trail. The crawler still amazes me as to the capability it adds to the truck.
The only bad things on the truck are as follows:
- Leather shifter boots for twin sticks aren't finished
- Some rock rash on the trim rings on the wheels, can be easily replaced at minimum cost
Asking $25,000. Remember the truck only has 21,000 miles!
Will also consider partial trades of either a 99-02 4wd 4Runner or 89-95 Extended Cab Pickup
21,000 miles!!
TRUCK OPTIONS:
- Cruise Control
- Tilt Wheel
- Roof Rack
DRIVE TRAIN:
- ARB rear locker
WHEELS/TIRES:
- matching spare
SUSPENSION:
Front:
- sway bar removed
Rear:
- Alcan AAL
- ATO shackle flip
ARMOR:
- ATO front skid
- ATO gas tank skid
EXTERIOR MODS:
- led bed lights
- UWS chest toolbox
- Safari Snorkel
INTERIOR MODS:
AUDIO:
