FS: 1985 4Runner SR5 SoCal
Garage Guy
1985 Toyota 4Runner SR5 22RE 5spd​
I'm the second owner of this truck. I bought her March 1998 with 185,600 miles.
Since then:
Front and rear axles overhauled with all new OEM bearings and seals.
Front knuckles overhauled with all new OEM bearings and seals.
New front 4.56:1 R&P with Detroit TruTrac.
New rear 4.56:1 R&P with ARB AirLocker.
ARB model RDCKA compressor with pressure gauge, quick connect, 20' coiled hose.
New transfer case 4.70:1 Marlin Crawler gears, bearings and seals.
W56 transmission complete rebuilt by Marlin Crawler.
Driveshafts overhauled and balanced.
New Alcan 2" lift stock length springs F&R with polyurethane bushings.
Rear Daystar greaseable shackles.
New adjustable drop drag link and adjustable torque rod.
Doestch Prerunner shocks.
Extended stainless braided DOT brake lines.
Extended diff breathers F&R.
New OEM vacuum lines and OEM spark plug wires.
New A/C compressor and evaporator converted to R-134A.
New 3-row brass "1-ton" radiator and new OEM fan clutch.
Custom reinforced rear bumper w/ 2" receiver hitch and 4-pin trailer connector.
Black Stallion steel roof rack on custom crossbars.
Optima Redtop battery.
Uniden Pro 510XL CB radio in center stack.
Firestik CB antenna with rear bumper mount.
300w 120vac inverter installed under passenger seat.
Alpine AM/FM stereo with 6 CD changer, Pioneer speakers in the doors.
BFG All-Terrain T/A 32x11.50 tires on American Racing 15x8 alloy rims.
40,000 miles ago:
New ProFormance 22RE long block, stock compression and cam.
New clutch, pressure plate, throwout and pilot bearings.
New water pump and radiator hoses.
Currently 327,775 miles on body and frame.
Body is straight, no damage, uncut except for trimming the front wheel well seam.
Professional polyurethane single-stage PPG paint is faded and oxidized.
(You've seen worse, but it is not great.)
New windshield was professionally installed, but it wasn't a very good job and
leaks have caused A-pillar rust through.
A couple other rust spots on the body.
Frame is straight, some superficial rust.
Drivers side front shock tower has been rewelded.
Interior overall good condition. Tears in drivers seat. Tear in headliner
above rollbar. Carpet needs cleaning.
Truck includes:
1985 4Runner and Truck (Gasoline) Factory Service Manual
1985 4Runner Users Guide and Users Manual
Pair snow chains fit 32" tires, never used
Car cover by North Coast Tarpaulin
Various spare parts.
Asking $4400. Located in San Diego.
More photos online: https://picasaweb.google.com/4Runner
PM or email with any questions.
Thanks,
--Paul
Toyotero
Great looking truck. It sounds like it's been well maintained.
I especially like the vent windows :-D
Garage Guy
There is corrosion through the A pillar metal near the windshield gasket at both the top and bottom corners on the passenger side. I am leaving it as-is to let the buyer repair as he sees fit, nor not. I could email photos but if you are local a first-hand inspection would be the best way for you to evaluate it. Let me know if you are interested.
--Paul
iStan814
