FS 2001 BMW R1150GS ABS Parting out - no accidents
wardlejp
I have a 2001 BMW R1150GS ABS that I am parting out. Most everything is still available, here is a partial list.
Accident free. Let me know what you are looking for.
No reasonable offer refused, especially on multiple parts. Paypal Accepted.
Body - Dash Shield ($20)
Body - Engine Crash bars ($150)
Body - Fender - Front (Yellow) ($125)
Body - Fender - Front lower ($40)
Body - Fender - Rear (Yellow) ($100)
Body - Fender - rear extender ($20)
Body - Foot pegs - Front - OEM ($50)
Body - Foot pegs - Rear - OEM ($50)
Body - Footpeg Mount - Front - Left ($85)
Body - Footpeg Mount - Front - Right ($85)
Body - Footpeg Mount - Rear Left ($50)
Body - Footpeg Mount - Rear Right ($50)
Body - Gas Tank (Yellow) Tank only ($300)
Body - Handlebar - Heated Grips (bar only) ($150)
Body - Headlight/Panel Carrier bracket ($100)
Body - Lock Set ($120)
Body - Rear brake pedal ($50)
Body - Rear luggage rack and handle ($75)
Body - Rear subframe ($300)
Body - Seat - Front - Mr Ed’s Custom ($250)
Body - Seat - Rear - Mr Ed’s Custom ($100)
Body - Shift Lever ($50)
Body - Stand - Center ($100)
Body - Stand - Side ($60)
Body - Stand - Side - Bracket ($25)
Body - Windscreen - OEM ($75)
Body - Windscreen - OEM - Tall ($100)
Brake - ABS - Control Module ($625)
Brake - ABS - Ring - Front ($50)
Brake - ABS - Ring - Rear ($50)
Brake - ABS - Sensor, Front ($50)
Brake - ABS - Sensor, Rear ($50)
Brake - Caliper - ABS - Front - L ($100)
Brake - Caliper - ABS - Front - R ($100)
Brake - Caliper - ABS - Rear ($100)
Brake - lever - front ($50)
Brake - Master Cylinder - Front ($100)
Brake - Master Cylinder - Rear ($50)
Brake - Rotor - ABS - Front - L ($75)
Brake - Rotor - ABS - Front - R ($75)
Brake - Rotor - ABS - Rear - R ($75)
Electrical - Alternator ($175)
Electrical - ECU ($300)
Electrical - Instrument Cluster - Rider information display ($175)
Electrical - Instrument Cluster - Speedometer ($100)
Electrical - Instrument Cluster - Tachometer ($75)
Electrical - Instrument Cluster - warning, turnsignals, gear cluster ($75)
Electrical - Lights - Brake Light ($50)
Electrical - Lights - High Beam (housing only – no bulb) ($80)
Electrical - Lights - Low Beam ($125)
Electrical - Lights - Turn signals - Rear ($50)
Electrical - Main Wiring Harness Cable Loom, Fuse box ($200)
Electrical - Starter ($100)
Electrical - Switches - Clutch ($25)
Electrical - Switches - Front Brake ($25)
Electrical - Switches - Sidestand kill ($40)
Electrical TPS sensor ($55)
Engine - Airbox assembly ($90)
Engine - Belt Cover ($40)
Engine - Front Cover ($60)
Engine - Fuel - Distributor rail ($75)
Engine - Fuel - Pump ($200)
Engine - Fuel - Quick connect ($20)
Engine - Fuel - Throttle body, Left ($75)
Engine - Fuel - Throttle body, Right ($75)
Engine - Oil radiator ($150)
Engine - Skid Plate (2pc) ($50)
Engine - Starter Cover - with accessory socket ($50)
Exhaust - Collector - OEM ($150)
Exhaust - Header - OEM ($150)
Exhaust - Muffler - OEM ($125)
Exhaust - Muffler - Super Trapp Slip-on ($200)
Luggage - Factory BMW mounts ($80)
Luggage - Side Cases (w/ Brackets) Hepco & Becker 42L ($425)
Luggage - Top Case (w/ Brackets) Hepco & Becker 42L ($225)
Suspension - Bottom Triple clamp ($100)
Suspension - Fork - Left ($250)
Suspension - Fork - Right ($250)
Suspension - Front telelever arm ($125)
Suspension - Shock - OEM - Front - 24,000 Miles ($100)
Suspension - Shock - OEM - Rear - 24,000 Miles ($100)
Suspension - Swingarm ($125)
Suspension - Wheel - Front - No rotors or ABS ($400)
Suspension - Wheel - Rear - No rotors or ABS ($400)
Transmission - Clutch - Hose ($50)
Transmission - Clutch - Master Cylinder ($100)
Transmission - Driveshaft (Both U joints) ($250)
Transmission - Final Drive ($300)
Simon Ashwin
Two Old Codgers
Are the shocks still available?
Also, are you selling the (and now I'm going to get really technical :) that silver rear part that sits under the pillion seat, houses the tool kit in the middle of it, and extends out the back where the rear luggage rack attachment gets affixed. Techie I know. See your 3rd photo
GS1150R
Parts required for my 1150GS
Hi,
Could you please let me know whether the forks and the trailing arm, inc. the ball joint, are still available?
Thanks
Alan
tango681
I am searching for the rear rotors.
I am in need of the rear rotor, I have a 2000 yr 1150 gs and believe yours will fit also looking for windshield and some other parts..do you still have them?, how can I get in touch with you directly? I my email address is tango681@gmail.com and will be looking for your email.
Please contact me at your earliest.
travelall74
