FS - 2002 Disco II - Kalahari Edition - $2500
Johnweil
Note: truck needs work- see post below for details.
The Good:
Special Vehicle badged Kalahari Discovery. 1 of only 100 white Kalahari's produced in '02.
In addition to all of the standard SE model equipment, Kalahari models came with the following items:
- saudi / gulf states spec front bumper and grille
- black painted hood
- tetra technical fabric seats
- black steel wrap around brush bar, lamp guards and rear ladder
- 16" "typhoon" style alloy wheels with black painted spokes and polished outer rims
- Kalahari badge featuring vehicle's limited production build number
- Safari Gard rock sliders
- lamp guards all around
Upgrades include:
- 2" OME lift
- center differential lock (upgraded transfer case and shifter)
- Borla exhaust
- upgraded front and rear driveshafts (OEM/ Great Basin)
- rotoflex upgraded to u-joints
- Rover Racks (now Voyager Racks) safari rack - contractor edition (full grid floor)
- (4) IPF 900 series lights
- (2) Hella Rallye 4000 Metal driving lights
Recent work includes:
- new catalytic converter
- new water pump
- all 4 O2 sensors replaced
- new brakes and rotors
- newer radiator
- newer power steering pump
- sunroofs resealed- w/ new drain pans and cleared drain tubes
The Less Good:
- sunroofs don't open (better that way)
- heated seats are currently not working (probably a fuse)
- small hole in passenger seat (see photo)
- headliner sagging (typical)
- lower portion of brush bar is dented (oops)
- slipped cylinder sleeve (ugh. needs engine rebuild or new block)- truck runs and drives but is prone to overheating so not recommended.
Located in Portland, Oregon. Truck would make a great off road build project - or there are enough bits and pieces to augment your current rig. Up until cylinder sleeve issue, truck was a daily driver.
I just got a JL Rubicon so ready to pass this to the next owner.
503 360 7837 call or text.
quigleyth
