illking
2009 KLX250s with 15,600 miles. This bike has every add on you can get. Bill Blue 351 big bore kit installed just over a year ago. Front and Rear suspension done by George at ESP last march. I guarantee this bike will blow away any other KLX250s. Ive added every bit of protection to make this even more durable than it came from the factory. I also have everything you need to convert to supermoto. In 30 Mins you can transform from a dirtbike to a supermoto. Very frequent maintenance with records while Ive owned it, On average I changed the oil and filter every 1,000 miles rather than the factories 7,500 mile intervals. Original tank, pipe, rear spring, fork springs, used set of tires w/ 30% more tread left, and extra odds and ends and take-offs come with the bike. Street legal, current tags. Fresh front tire and lots of life left in the rear Motoz desert tractionator.
Asking $4300 for everything including supermoto set up. $3900 for bike w/o supermoto set up.
over $3800 went into this bike not including any installation costs.
Parts list
BB 351 big bore kit 533.95
ESP suspension 800.00
Warp 9 black anodized rims 210.00
Two brothers slip on exhaust 319.78
Dynojet Jet Kit 49.99
Ricochet Offroad Skid Plate 94.99
Zeta Armor Pro Bend Hand Guards w/ Turn Signal Plastic Shields 131
Works Connection Rear Caliper Guard 26.99
Unibiker radiator guard 99.99
IMS tank 274.95
IMS wide pegs 39.95
EBC Clutch Kit 54.99
Barnett clutch springs 20.00
Tusk 1.6 High Pressure Radiator Cap 14.99
Engine ice 19.99
NGK Iridium Sparkplug 10.00
Tusk Handlebar Riser Kit 18.99
Motion Pro Rim Lock 16.00
Bridgestone Ultra Heavy Duty Motorcycle Tube 68.00
Pro-Taper SE 7/8" Handlebars CR-high 59.99
Speedo drd 80.00
EDGE2 TAIL LIGHT w processor upgrade board 182.00
Kriega cam chain tensioner 38.00
KLX300 clutch cable 20.00
New side plastics 80.00
total spent 2949.64
Supermoto kit
Acerbis Super Motard Front Fender 23.99
front and rear axle slider 103.25
09 KLX250sf wheelset,tires, rear sprocket, front brake rotor and front brake caliper bracket 1000.00
total spent 1127.24
Parts list
IMS tank 274.95
IMS wide pegs 39.95
Engine ice 19.99
Speedo drd 80.00
total spent 2949.64
Supermoto kit
total spent 1127.24
