FS: 2021 Four Wheel Camper $26000 obo Wichita Kansas
jesseg
Built new December 2021 . I will sell camper separate from truck.
I built this for expeditions to high altitudes Colorado and for Alaska trip.
THE FOUR WHEEL CAMPER RAVEN $26,000 or best offer. Build was $30,500 I may be able to deliver for your truck.
Four Wheel Campers Raven 2021 install Rocky Mountain Four Wheel Campers Juniper Overland Denver. Like New
I ordered the Raven last year at the Overland Expo in Loveland Colorado. Took many many months to get this new from factory.
Mechanical Camper Jacks, Dometic Forced Heater, 2 Propane tanks, Upgraded Flush Mount Stove top 2 Burner, MaxAir @2 quiet with remote powered roof vents, Fiamma F45S Awning with Awning Light, Yakima roof racks, Rear Wall Steps, 2 Chin 100 ah internal heated Lithium batteries that charge in cold weather, Victron Orion Smart HQ DC to DC 12v-30amp Isolated battery charger from truck, Victron Smart BVM HQ battery display, Victron Smart Solar MPPT 100/30 solar charger to batteries from solar panels, Victrons are all Bluetooth, LifeP04 20 amp Lithium charger connected to shore power connection. Upgraded Digital Thermostat for Dometic heater, Adjustable RV table, 200 watt Rich solar, to the fwc 160 watt total 360 watts solar with upgraded wiring, Krieger 1500w 110v inverter, 2 Actionpack for traction mud, snow, sand, extraction on top of Raven, Rear flood lights, Thermal Pack, Small driver side window, Large passenger side window, Rear wall 110 volt ac Air Conditioner, Queen Bed, Removable Carpet, Camper jack extension, upgraded silver spur complete package inside and outside, Two step entry quick removable into camper, 2 Roto Pack 2.5 gallon fuel tanks with Aluminum holders, Lower platform to sleep on when not lifting top. BougeRv refrigerator\freezer with 12 volt or110 volt.
jesseg
Reply to will this fit my F350?
I originally had this build for my Ford Raptor with short bed and light weight. Well we specked it out thinking it would weigh around 825ish lbs like it says on the back of camper . Well the manifest said 1107 lbs, was a surprise and when I got home it was 1100ish. Basically right at the max caring capacity of the Ford Raptor I own. Due to potential liabilities issues for over capacity I purchased a 2020 Ram 2500 February this year with a 6 1/3 bed measured around 74-76 depending how you take into account the tailgate. So I placed the Raven on the longer Ram 2500 bed pretty much same size I think as your f350? and figured out that a 3 inch square tubing installed in the front lower of the bed for the bump stops to set against allowed me to get proper anchoring mounts for the turnbuckles due to the wheel wells and bingo it worked awesome and let me place my retropack and slide 2 chairs between truck bed and Raven.
