FS: 20ft Aluminum Enclosed Trailer / Camper / Toy Hauler $3000 obro
Diesel-X
b]All Aluminum Enclosed Trailer[/b] - 10,000lb rated (2,870 empty trailer weight)
Great for Construction or Camper, Snowmobiles, Dirt Bikes, Quads, ATVs...etc
20 x 7.75 x 6.75 inside dimensions
25ft overall length (bumper to hitch)
12,000lb-rating surge brakes and 12K trailer Jack
Dana 80 HD axle - with recent Calipers, Rotors, pads and brake fittings/lines.
19.5 Heavy Duty wheels/tires - with full size Spare. Includes racking shown in pics, bike lift/jack and bench seat if you want them....
$3,000
Located:
Biddeford Maine
Call or txt TWO ZERO SEVEN - 702 - ZERO ZERO ONE ONE
Thx,
Chad
The Adam Blaster
That's a really cool idea - I would like to see the axle closer to the center for good weight distribution, but it's pretty cool none the less. :victory:
Terrainist
The square tongue is concerning. Interested buyer, be sure to make sure you are cool with the turning radius. Only from looking at the photos - if this trailer were to get jacked, it might taco a bumper.
Looks like it might be big enough to park a vehicle in. Cut eight feet off the front for better weight distribution, sell the aluminum for scrap.
Diesel-X
Axle location to the rear makes it tow kinda like the heavy duty "low-boy" trailers that have the axles all the way at the back. never sways but does have some tongue weight. 3/4ton trucks like air bags or helper springs.
The square end has only seemed to be an issue on bumper style class3+ hitches... anything with some length that sticks out past the bumper and/or lower than the bumper can get almost 90deg.
Also they make extended reese-type hitch inserts as well as the ProPride or trunion style hitches extend length away from bumper.... just some thoughts we've had.
40,000lb capacity LowBoy example....
Diesel-X
Surge Brakes - as the vehicle decelerates the trailer prefers to continue moving forward - that energy is transferred into the surge brake hitch causing the trailer tongue to compress a hydraulic piston that actuates the disc brakes. Once the trailer slows itself enough to relieve the compression force the brakes release.
Hook-up is 2-5/16 ball and 4-pin for wiring.
Greggk
ZombieSoldier
wow this is simply awesome. this would be mine if we were a lot closer. goodluck with your sale and free bump for you!
