FS: 325/80/16 Pro-comp X-terrains on centerline wheels
I'm selling a set of four tires and wheels. The set has four 325/80/16 Pro-comp Xterrains mounted on aluminum wheels that appear to be Centerline Hellcats. Two of the tires are 70-80% tread and the other two are 60% One of the wheels was run on the truck for a little over a mile with loose lugnuts, therefore the holes on the wheels have been damaged. They are likely fine for use off-road, or can definitely be repaired for use on road. The tires alone cost around $450 each new. Asking $650 for everything. Wheels are located in Knoxville, TN. On to the pics :sombrero::
Goldenbora
