FS: 98 6.5 K1500 Suburban running dual tank WVO
murph
Runs great, but my commute has changed from 65 miles one way down to about 10, so I can't run the truck on VO…
98 K1500 Suburban LT
Leather, 3rd row seat, AC, PW, PDL
250K miles
3.42 gears - ~17MPG highway
Professionally converted - http://www.greasecar.com/forum_topicview.cfm?frmtopicID=5032
2 tank WVO system – stock tank for VO, 10 gallon diesel tank
VO Tech valve block
Frybrid heat exchanger
Sony stereo, Infinity speakers
Heath PMD remote mounted under front bumper, spare PMD in glovebox
Mechanical Heath Turbo Master wastegate control
New oil cooler with braided SS hoses
Alternator/starter/IP replaced in last 50K
Starter and battery cables replaced with 2/0 welding cable
Both front wheelbearings replaced in last 30K miles
Cryo treated front rotors installed less than 30K miles ago
Glow plugs replaced 1/09
Also included is the 4 volume FSM set, never installed aftermarket exhaust crossover pipe, and a spare IP that I bought as a core. It's a warranty take out, so most likely it's only the PMD that's bad.
I'm in Mohegan Lake, NY (on the Westchester/Putnam border)
Asking 6000 obo
(914) 649-2230 or murph@jonfund.com
bahndo
Supporting Sponsor: Bahn Camper Works
4x4 or 4x2? guessing by the heath PMD mounted to front bumper it's 4x2...
murph
Ah, nope... :) "K" in a Chevy truck model # is the 4WD version.
The PMD is acually on the plastic splash pan behind the bumper.
Andy
murph
Some inside pics...
Also included is a full 55 gallon drum of VO, as well as an empty drum and a 12v transfer pump.
iStan814
