FS: Expedition pop-up trailer project -- $500, KC area
KCfit
Planned expedition pop-up trailer project stripped down to the frame/fiberglass shell with good canvas — project has stalled
$500
Kansas City area
Starting point
  • 1960s Kampcraft Capri pop-up trailer WITH title
  • Axle flipped
  • Mounted larger tires -- 265/75R15 Goodyear Tracker 2 tires with good tread
Condition -- this is a project
  • Pulls great!!!
  • Frame -- good condition with surface rust and single busted weld that has been repaired, hitch works well, new adjustable front landing gear that works with new height
  • Fiberglass — has been previously painted and has numerous small holes from past hardware, several larger scratches (nothing that cannot be easily filled/patched
  • Canvas — installed/removed easily via channels, canvas itself without holes, window zippers function well, insect netting has large holes that must be repaired
  • Pop-up mechanism — spring-assisted, working as manufactured — easily raises/lowers
  • Interior — bunks/cabinets/table all removed and need to be replaced due to rot/delamination BUT I have kept all hardware and interior wood to use as template for replacement
  • Electrical — have new rear turn signals
  • Back door -- aluminum in very good condition
Specs
  • Total L (including tongue/hitch) 12’8”
  • Box closed 9'4" L x 3' H (closed) x 6'10" W
  • Box open 7'4"H
  • Ground clearance 24" to box, 20" to axle
Trailer w/ canvas installed (prior to starting project)
Current State
Vintage Ads for Trailer
Interior Demonstrating Bunk Configuration (upper bunk folds down to be bench back, bottom bunk converts to table/booth)
iStan814
