FS: Ford Econoline 2WD Weldtec 6 Inch Lift
jblaze5779
I have a Weldtec “Grocery Getter” 6 inch lift for sale. This is labeled as the 6” baja grocery getter on their website. This lift was used for approximately 18 months on a 2001 e350 7.3l and has about 5,000 miles on it. It is still assembled so you could technically just weld on the flanges, take off the existing suspension and throw this one on. Easy peezy. You will need to source rear blocks and shocks.
Baja Grocery Getter:
  • Bent I beams. 6″ (all I beams have new pivot bushings)
  • Painted extended radius arms with 6″ lift Coils
  • Radius arm pivot bushings
  • Upgraded 2.0 fox (front) shocks with custom valving by Agile Off Road.
In addition to the lift there is an extra value… the following were replaced when the lift was installed:
  • moog upper and lower ball joints, both sides
  • all moog steering tie rod ends
  • front spindles and wheel bearings, both sides
  • turned rotors and new pads
  • Abs sensors (You will need to splice your abs sensor connector to the sensor installed on the hub)
  • Speed bleeders installed on calipers
This kit is listed for sale at $2,520 on weldtec’s website. I will sell directly to you for $1,900. I am located in Texas.
iStan814
