FS: Jeep JKU Hardtop Freedom top with AEV Rack and ARB Awning
2012 JKU freedom top with removable panels and AEV rack mounted. Hard top is in excellent condition with only a couple minor scratches from transferring it on and off the Jeep. The rack is removable, leaving the feet in place while not using, as seen in photos. Additionally I've surrounded the feet with roof caulking as well as over the bolts that go through the top to ensure no potential for leaks (this is silicone based, so you can peal it away if you don't want it).
What's included:
-AEV hardware
-AEV satellite relocation bracket
-Extra set of OEM roll bar padding so you don't have to cut into yours to install the brackets
-ARB 8' awning mounted (never used)
-Deck seal to run wiring through top to rack
-Rear light mount
What's not included:
-IPF rear light pictured
-4 of the 8 bolts used to secure the hardtop to the jeep, regular hardware or aftermarket replacements will be needed
$1800 OBO. Local pick-up only.
Xodius
Do you have a photo of the inside/the underside of the feet? Is it reinforced with flat steel or?
On the underside feet attach to a bracket that is bolted to the roll bar. Pictured are the rear brackets. The front brackets are hidden by the sound bar. Additionally are a couple more shots of the rack.
iStan814
