FS: Maggiolina RTT in SoCal-SOLD!!!
HMR
Rendezvous Conspiracy
The "buyer" from my previous thread sent a deposit then decided not to do the 12hr drive to pick up the tent. So here we go, again...
This is an "ON LINE" model from Maggiolina. The model is no longer made but is pretty much identical in weight and dimensions to the Medium Extreme.
A pic from our last trip:
The fiberglass has lots of scratches from countless adventures. Cosmetically, the fiberglass shell is in "fair" condition. Structurally, it's free from cracks and holes and is 100% waterproof. The fabric walls are in excellent condition. The mattress has always been covered and still looks and feels like new. Tent is located at Palomar Airport in Carlsbad, CA. SOLD!
HMR
The left side has two scuffs near the front and rear corners:
Right side:
Rear:
Headliner has a spot that's worn from ladder being stored inside:
This model was designed to only have the ladder on the left side (new versions are designed for either side). The old ladder had hooks on the end and poked a hole in the wood the first time I tried to enter on the wrong side (Doh!). Damage is cosmetic only:
We've since replaced the old steel ladder with the new aluminum version. It can be used on either side.
All screens, flaps and zippers are in perfect condition:
Tent comes with aluminum ladder and all mounting hardware.
2 Thule load bars can also be included if the buyer needs them.
brentbba
Where were you before I plunked down almost the same amount for a Springbar ground tent! And you are local too!! Bump
HMR
What is the dimension of the sleeping surface?
The actual mattress is approx. 70" by 53".
The entire, usable, sleeping surface is approx. 79" x 55".
Maximum height between the mattress and ceiling is 37".
iStan814
