FS: Mall Crawler 4x4 - 2003 Mitsubishi Montero Sport Limited
2003 Mitsubishi Montero Sport Limited A/4WD
124,662 miles and rising, I believe everything works to some degree or another. Runs and drives good, definitely not perfect but it gets the job done. Side steps are included but not installed. This has been in the family since 11k miles and before that the owner of a Mitsu dealer's wife drove it. Here is a mostly complete list of maintenance. I do have some paperwork for lots of it. Rear Heat, Heated Seats, Aftermarket radio with USB and Bluetooth, Rear LSD, Full Time Awd with option for High and Lo, trailer hitch, rear helper bags, Sunroof, etc....
Date Mileage Service
11,000 Purchased
8/12/2005 31850 Front and Rear Brakes
3/9/2006 36941 Trans Service
40000 Coolant
Diffs/TC
10/2/2007 49,800 New Battery
10/12/2007 49,800 PCV Valve
2/16/2008 53030 2 Tires
3/6/2009 60396 Rear Brakes/Belts
4/17/2009 62306 Front Brakes
11/8/2010 75,550 Rear Bilstein Shocks/Fuel Filter
4/5/2011 76676 Timing Belt/Spark Plugs/Wires/Intake Gaskets
7/26/2011 77840 Radiator/Coolant
8/4/2011 78,033 2 Tires
10/31/2011 Trans/Diffs/TC
10/31/2011 80,500 Air Filter
7/10/2013 92,725 Rear Brakes
08/01/14 99000 Front Shocks
06/03/15 Rear Calipers
03/01/16 111000 Belts and Tensioner Pulleys
03/06/16 111000 New Battery
03/07/16 111100 Power Steering Pump Seals
03/12/16 111600 Ball Joints, tie Rods, sway bar bushings
04/15/16 4 Tires
12/15/16 118000 Diffs/TC/Trans Fluid/PCV Valve
07/05/17 120000 Alternator
01/01/18 124000 Oil Change
$3,333.33 OR BEST OFFER.... Bring cash and we can make a deal!
The Mall Crawler is located in Palos Heights, IL.
Herb colvert
