FS MPPT Solar Charge Controllers: Morningstar and Midnite Solar
Kiomon
Hi Expedition Portal Family!
We are doing a bit of a refit of MogTug (www.nicknameinternational.com), and are changing a bunch of components over to Victron to support a new app project we are working on. As a result, we have a bunch of components that work perfectly that are for sale. Prices are firm. Best way is to pm me here on the forum. Items will ship from Chicago, IL
Morningstar Tristar TS-MPPT-60 Charge Controller - $375
-This is a 60 amp MPPT charge controller from Morningstar. It has full networking capability and programmability. This unit has been flawless for us. One note, that we remembered as we took the unit down today; after we first installed it, our solar array cable wasn't as tight as it should have been, so the terminal heated up and started to warp the plastic protector. We tighten it down, called Morningstar and sent pics, and they said it was fine. It's been two years since then and no issues. I am posting pics, below as I am anal, and if you look closely you will notice the warping on the yellow protector.
This is their top of the line controller. This pairs nicely with the TS-RM-2 remote (below), so you can monitor the amps in and out. You can configure the unit using dip switches on the unit, if you want to further customize the unit, then you will need the interface kit I am selling below (only lithium installations are likely to need it) or you can configure it via the Ethernet port and Morningstar software (free).
- http://www.morningstarcorp.com/products/tristar-mppt/
Morningstar TS-RM-2 Remote Display `- $50
- This is the meter display to show all the data from the Tristar MPPT series charge controllers. The connection cable is a simple phone cable and its included. This is meant to be mounted onto a panel or wall and the charge controller tucked away somewhere else (ideally close to batteries!)
- http://www.morningstarcorp.com/products/tristar-remote-meter-2/
Morningstar Sunsaver MPPT 15 - SOLD
- This is a 15 amp MPPT charge controller from Morningstar. This is a great option for a smaller solar installation. You can configure the unit using dip switches on the unit, if you want to further customize the unit, then you will need the interface kit I am selling below (only lithium installations are likely to need it)
- http://www.morningstarcorp.com/products/sunsaver-mppt/
Morningstar RM-1 Remote Meter - SOLD
- This is the remote meter display for the Sunsaver MPPT charge controller. This shows the output of the controller. Works great! This is NOT compatible with the Tristar charge controller I am selling. This will come with the cable to connect to the Sunsaver (it's a standard RJ12 phone cable )
- http://www.morningstarcorp.com/products/remote-meter/
Morningstar PC Meterbus Adapter + Serial to USB adapter - SOLD
- This is a specialized interface to allow you to use free Morningstar Software (MSVIEW) and fully customize the controller. We used it to put in custom Lithium charging profiles into each of the controllers. A normal install doesn't require this, but it is handy. This adapter connects via phone cable to the controller, and serial on the other end. I am also including a serial to USB adapter so you can use a normal recent computer.
- http://www.morningstarcorp.com/products/pc-meterbus-adapter/
Midnite Solar Kid 30 Amp Charge Controller - SOLD
- This is just 2 months old! Midnite Solar Kid 30 AMP MPPT charge controller. It has a built in display that allows you see what the unit is producing and also to customize some of its features. You can add a piece called a Whiz bang Jr (real name), that is a shunt and will show you battery SOC right on the unit itself. Excellent option for most systems under 500 WATTS
- http://www.midnitesolar.com/product...e=Software&productCat_ID=43&sortOrder=1&act=p
Handyman7665
I'm interested in the morningstar mppt 60 if it's still available ,I'm needing one more , please let me know if it's still available
wellsasw
