KlausVanWinkle
This is a barely used Nemo Tango Duo Slim sleep system with slipcover. This bag has been great. I've only used it 4 nights, always using a sleeping bag liner. Always stored uncompressed in the included storage sack with a dryer sheet to maintain a fresh smell. The only reason I'm selling is because I bought the slightly wider version from Nemo as a special order. No stains, doesn't smell.
Also included are 2x Therm-a-rest Luxury Map 20R (20x" 72" x 3") self-inflating sleeping pads. The sleeping pads were also used for 4 nights throughout the last year. They're in near flawless condition. Both pads still self inflate to their full thickness in less than an hour. They come with the original stuff sack, tags and owners manual.
This sleep system has been great for tent camping, sleeping in an SUV or a narrow roof top tent. The edges of the bag are waterproof. So touching tent walls isn't an issue. The entire backless sleeping bag system takes up as much room as a single down mummy bag. My wife and I have been plenty warm using this bag with a fleece sheet right up to and slightly below the rated temperature.
I will separate the items.
$250 Nemo Tango Duo
$70ea Thermarest Luxury Map Sleeping pads
Includes:
700 Fill Power Down with DownTek™ 2-person Sleeping bag w/detachable hood.
Slip cover that holds 2x 20" wide sleeping pads.
Stuff sack for slip cover.
Stuff sack for sleeping bag
Storage sack for sleeping bag.
2x Therm-a-rest Luxury Map 20R (72"x20"x3") self-inflating Sleeping Pads
2x Sleeping Pad stuff sacks with tags and owners manuals
Specs:
Temperature Rating 30F / -1C
Fill Type 700 Fill Power Down with DownTek™
Fill Weight 1 lb, 4 oz / 570 g
Minimum Weight 2 lb 9 oz / 1.16 kg
Shape Rectangular
Capacity 2P
Fits Up To 6'0" / 183 cm
Shoulder Girth 72 in / 183 cm
Hip Girth 72 in / 183 cm
Knee Girth 72 in / 183 cm
Pad Sleeve Dimension Two 20 x 72 in / 51 x 183 cm
Packed Size 18 x 10 in dia / 46 x 25 cm dia
Compressed Volume 7 L
Zipper Location N/A
Shell Fabric 20D Nylon Ripstop w/ DWR
Footbox Fabric 40D Nylon Ripstop w/ OSMO™
Lining Fabric 30D Nylon Taffeta w/ DWR
Color Aluminum / Marigold
Bag without hood attached.
Back of bag and flap where pads slip in.
Washable sleeping pad slip cover/sheet
Removable bad hood
Bag and slipcover stuff sacks
Storage sack
Sleeping pad (1 of 2)
Backside
Stuff sack (1 of 2)
The end grab handle ripped out on the one stuff sack the first time I used it. Functional otherwise.
$250 Nemo Tango Duo
Includes:
Specs:
Shape Rectangular
Capacity 2P
Zipper Location N/A
Removable bad hood
Storage sack
Backside
Stuff sack (1 of 2)
