FS: Pelican 1650 cases $130
goomashoom
Pelican 1650 Rolling Large Case w/ Foam
$130 each
Located in San Mateo or Daly City, CA.
Willing to ship on your dime.
I have several large Pelican 1650 cases for sale, some with, and some without foam. The 1650 is a very large case for storing larger items. The 1650 has seven lid latches for security, as well as a sliding handle and wheels for carting around heavy items. Three different grab handles on three sides of the case can be used for lifting. The steel padlock protectors provide added strength and extra security against theft
Has the easy-to-open double latches. All rubber O-seals are intact. All handles are intact. All wheels are intact. Scruff marks from shipping via UPS.
Exterior Dimensions
(L x W x D) 30.75 x 20.5 x 11.62"
Interior Dimensions
(L x W x D) 28.5 x 17.37 x 10.5" (5,200 cubic inches)
More details at Pelican’s and B&H’s websites:
http://www.pelicancases.com/1650-p/1...FRDZQgodah8AEA
http://www.bhphotovideo.com/c/product/75519-REG/Pelican_1650_020_110_1650_Case_with_Foam.html
Weight: 24 lbs (without foam)
Lid depth: 1.87”
Case depth: 8.62”
The 1650 is an unbreakable, watertight (IP67), airtight, dustproof, chemical resistant and corrosion proof hard case used to carry any kind of equipment that needs to be protected from the elements. It is made of Ultra-high Impact structural copolymer that makes it extremely strong and durable. It has a 0.25" (6.4 mm) neoprene o-ring, ABS latches that seal perfectly and includes an automatic purge valve for quick equalization after changes in atmospheric pressure.
The 1650 comes with a top handle, oversized side handle, a retractable extension handle and strong polyurethane wheels with stainless steel bearings. It has an effortless release latch for the extension handle. The padlock protectors provide added strength and extra security against cutting and theft.
goomashoom
Sorry for not replying sooner. I'm sending out a case on Monday. I think the cost will be around $40 for UPS ground. I'll confirm tomorrow.
goomashoom
Shipping cost $50 UPS ground to Northern California. I live in Northern California so ground shipping across country might be a little more.
flipstick
