FS - Rock Krawler 3.5" X-Factor JKU Lift
harv3589
First off I'm in Canada...but I know there are a few of us on here so maybe someone would be interested.
Rock Krawler kit for sale, includes the following
(4) Long travel functional multi rate coil springs
(2) Double adjustable track bars made from 1.5" solid alloy steel with Anti-Wobble joints
(4) High clearance adjustable lower control arms made of 1.625" solid alloy steel
(2) High misalignment adjustable front upper control arms made from 1.25" solid alloy steel
(2) High misalignment adjustable rear upper control arms made from 1.25" solid alloy steel
(2) Adjustable front sway bar disconnects (JKS)
(2) Rear extended sway bar links
(1) Rear track bar relocation bracket
(2) Rear coil spring degree wedges
(4) Braided brakes lines
(1) Teraflex exhaust spacer kit
(1) Teraflex quick disconnect bracket kit - (replaces the disconnect straps)
Now included Teraflex exhaust spacer kit new in box and RK front and rear brake lines!!!
$2000 for lift no shocks
Not included are the disconnect straps. Lift is in excellent shape and has only 15,000kms on it.
***If the buyer is interested in the Prodigy Shocks to make the lift a full stage 1 lift I would interested in selling them***
$2600 with the shocks
HButton
