FS: XVenture XV-1 w/ electrical, Rigid lighting, bedliner, Goal Zero batt
VisualUniverse
* * * S O L D * * *
Trailer: XVenture XV-1
Price: $7,500
Features:
- electrical
- 6 Rigid lights mounted high
- rock lights
- bed lights
- crossbars
- awning brackets
- bedliner
- Goal Zero Yeti 400 battery in front battery box
- I'm keeping the offroad tires/rims. Included steel rims and tires are new.
- MaxCoupler hitch
- brakes (controlled via brake controller, and manual locking brakes for set-up)
- rear stabilizers
- Iron Man awning
- Goal Zero solar panel for charging battery
Pictured roof top tent is not included.
I purchased it new in Spring of 2015.
Rear Rigid light provides sufficient illumination...
Dang, I am that guy. A newb asking stupid questions. Sorry for Being so dense, viewing this site on the iPhone can be challenging for my old eyes. I now see is trailer only.
Even after re-reading the post, I wasn't sure about the trailers age.
VisualUniverse
LOL...no worries. Trailer is 2 years-old. I purchased it new in Spring of 2015.
VisualUniverse
An ATV will fit in the trailer. I believe the rack can be elevated, but I will have to check when I get home. I have not had a need to elevate it.
VisualUniverse
As configured, can you easily drive an ATV into the trailer? Can the rack be elevated?
The answer to the "can the rack be elevated question" is both yes and no. My trailer has the towers that allow for elevated rails/roof rack. As you can see in the photo, there is a hole...that is for the pin when raising the inner shaft. I don't have the inner shaft. Instead, the rails are fixed at the top of the tower with a bracket. To elevate, the following would need to occur:
- purchase the inner shaft and pin for all 4 towers
- remove the bracket off of each tower
- lengthen the light cabling for all 6 Rigid lights
eddyoz
