As I go through the process of swapping my 4G54B for a 4G64 I've started planning for all of the associated requirements to support the engine. Obviously the newer engine is fuel injected and will require an electric fuel pump which made me wonder about using a raider v6 setup. Does anyone know if the fuel tanks between the 4 cylinder and the v6 trucks are interchangeable? I think swapping tanks, with an in-tank pump, would be the cleaner, more elegant solution for the upgraded engine and, if I'm reading everything correctly, I'd gain about 4 gallons of fuel capacity too.
Has anyone ever done this before?
James
James
