FWC wiring question
MileHiJeepGuy
Curious as to how most connect a Four Wheel Camper with the 3 prong trolling motor connector to a newer 7 pin in bed connector. I cannot seem to find an adapter and assume I will just cut off the end of the 3 prong connector and replace it with a 7 pin. Thoughts? Thanks in advance!
Martyn
No adapter that I know of. You can rewire to a 7 pin no problem. Three wires, ground, 12 volt power, and ground. The smaller campers are not wired for lights.
Pax2525
I've had a similar thought and couldn't ever find anything so I thought I would just wired the 2 adapters together.
Sparse Gray Hackle
Morgan Freeman Imposter
It's an Attwod trolling motor plug... Walmart had them, maybe they still do. Just look in your owner's manual or on the Internet for how the 7 pin is wired. You have power, ground and clearance lights to configure.
Josh41
My Fleet has a dedicated trolling motor mount from the battery into the bed of the truck, it is fused. My understanding is that your 7 pin connector does not offer enough amps to charge the battery.
Josh
project13support
