FYI about Chilton manual for 1983-1995 Pickups and Monteros
Hey guys, just an FYI!
Chilton's manual 50500 1983-1995 Mitsubishi Pickups and Montero.
I wrote in the correct sequence.
No **** Sherlock. But the fookin FSM isn't clear, and I have the paper version! When you have a diagram like the one expressed clearly in the Chilton's manual..... which one would you go with???
off-roader
Well its CLEARLY incorrect so a lot of good a clear diagram did.
Hill Bill E.
Oath Keeper
How is that wrong? It's not showing the firing order, it's showing the piston order.
Farthest front is #1, and the rest on that side are 'odd' (for a V8 that would be 1-3-5-7) and the second to the front is #2 (and for a V8 2-4-6-8)
I don't see where the manual is wrong?
Well, I should have marked the letters in the drawing above that also:
Spark Plug Cable #1
Spark Plug Cable #3
Spark Plug Cable #5
Which.... translates to:
2-1
4-3
6-5
Ah! My old fuzzy eyes couldn't cipher that. LOL I can barely make out the 'Spark plug Cable..', but not the #'s
The cylinder layout is correct (at least for a right hand drive rig)
Yeah, sorry for that.
So to be clear, the cylinder order is correct but the wiring sequence is not. In the FSM, it simply shows a drawing with the wires going to the corresponding cylinders...... but the criscross making it nearly impossible to decipher.
GrassCat
Here insert this in your Chilton's manual.
I can't make out the text in your picture to tell if it's wrong or not, so I'll have no comment on it. I certainly don't want to be called a smarty pants for making a comment.
I apologize, Ray and Michael, for my seemingly harsh statements.... As we(I) were quite furious about this crap. Wasn't meant to be portrayed upon you guys. :beer:
