Gap tool tight tolerance alignment
bentonrover
Was wondering on this for future alignments on my LR3. Should my settings be at entry level, normal, or offroad height? Also should I make adjustments prior(on the way or parking lot) ? Or while on the alignment machine? Thanks
unseenone
Four-Wheel Alignment (57.65.04)
NOTE:
1. Check the tie rod ends, suspension joints, wheel bearings and wheels and tires for damage, wear and free play.
2. Check and adjust tire pressures.
3. Position the vehicle on a calibrated, level, vehicle lift.
4. Release the vehicle parking brake.
5. Check the suspension ride height.
Ride Height Adjustments (60.90.03)
Specifications
Specifications
6. NOTE:
Using only four wheel alignment equipment approved by Land Rover, check and adjust the wheel alignment.
Specifications
7. NOTE:
CAUTION: Make sure the vehicle is on a flat level surface.
CAUTION: Make sure the tire pressures are within specification.
CAUTION: Make sure that only the manufacturers' recommended four wheel alignment equipment is
used.
CAUTION: Make sure the vehicles fuel tank is full, if not distribute extra weight evenly over the fuel tank
area to represent a full tank of fuel.
CAUTION: Make sure there are no heavy objects in the vehicle.
CAUTION: Make sure the air suspension is set to NORMAL ride height.
CAUTION: Make sure the steering is in the straight ahead position.
This procedure can be used on vehicles with either air or coil spring suspension.
<snip>
iStan814
