Garage Sale : Jeep TJ & Builder Parts
GP'd
Garage Sale
Currie CE-9121 - Track Bar Relocator Barcket
http://www.currieenterprises.com/cestore/product.aspx?id=1173
Part #: CE-9121
New : $74.95
Condition : NEW IN BOX
Asking : $65 Shipped.
Description: Our rear trac bar relocator bracket for 1997-2006 Jeep TJ's and LJ's. allows the trac bar to be installed at the proper angle and position after a lift kit is installed. The bracket bolts on the rear axle housing and relocates the Trac-Arm pivot point. It is made of heavy duty steel has a powder coated finish and includes all mounting hardware.
Bilstein Shocks
Front Bilstein (24-024426)
http://www.quadratec.com/products/16070_105.htm
0" Lift, 20.41" / 12.68" Eye / Stem
Rear Bilstein (24-024433)
http://www.quadratec.com/products/16070_106.htm
0" Lift, 19.07" / 12.40" Eye / Eye,
New: $76.99 Each
Condition : Good (~50,000 Miles)
Asking $100 Shipped
Description : Self-Adjusting Deflecting Disc Valving, High-Flow Piston Reduces Harshness, Independent Rebound & Comprssion Tuning, Larger Working Piston Area for exact dampening. Superior control for larger diameter tires.
Teraflex Budget Boost
http://www.teraflex.biz/tj-wrangler-1-5-budget-boost-lift-kit.html
Part #: 1341200
New : $130.99
Condition : Excellent (missing bumpstop extensions)
Asking : $75 Shipped
Description : This kit is the most economical solution to lifting your Wrangler. The budget boost will provide enough lift to run a 31x10.50 tire. The budget boost will provide two inches of lift when combined with factory rubber insulators (1.5" without). Fits all Wrangler models including Rubicon and Unlimited.
TJ Add a Trunk
New : ~130 ish.
Condition : Fair
Asking : $40 Pick Up Only
Steering Linkages
Factory TJ Steering & Track Bar
Condition : Used
Asking : $20 for both.
Factory ZJ Steering Linkage
Condition : Used
Asking : $60
Jeep TJ Factory Seat Belts
Condition : Used
Asking $100 for the set. Includes all adjusters. Brackets in top left are for Rear Seat (Not included)
Jeep TJ Factory Sahara Seats Front & Rear
Condition : Used - Great Condition
Asking : $300 for the Set
2000 Ford Explorer Sway Bar & Diff Cover (8.8)
Condition : Used
Asking : Get it out of my garage. Going to metal scrapper in 1 week.
Synergy Suspension TJ Harness Bar
http://www.synergymfg.com/synergysu...ulder-Harness-Bar-for-Stock-Cage-p-26265.html
New : $50
Condition : New in box.
Asking : $40
Description : Manufactured from 1.5 x .120 DOM Tubing, Bent and notched for quick weld on installation, Designed for aftermarket shoulder harness seat belts
Jeep TJ Factory Hood - OEM
Condition : Used - Good
Asking $150
AEV TJ Highline Fender Flares
http://www.aev-conversions.com/shop...t/tj-highline-body-kit-highline-body-kit.html
Condition : New in Box
New : $324.00
Asking : $300 (Shipping Negotiable)
Jeep TJ Fenders & Fender Liners
Condition : Used and Cut
Black Set (Cut for shock towers and boat sides)
Green Set (Inner Fender Separated from Outer)
Liners : Cut for Shock Towers
Asking : Get them out of my garage
Jeep TJ Fender Flares w/ Indicator
Condition : Used
Asking : $40
Ford Factory 3.73: 1 Gearing
Condition : Used - Great Low Miles < 75,000
Asking : $80
Spicer/Currie 2-2-939 with Hardware
http://www.currieenterprises.com/cestore/Product569.aspx?id=1043
New : 39.95
Asking : $30 Shipped
Ford 8.8 1310 Series Flange Adapter - Dana Spicer - 2-2-1379
New : $30
Asking : $25 Shipped
Jeep TJ JKS Swaybar Disconnects
http://jksmfg.com/i-13306763-wrangler-tj-1997-2006-quicker-disconnect-fits-0-2-lift.html
Condition : Used - Fair (Conditionally working fine) Needs new bolt/Slight damage to one pin.
New : $175
Asking : $75
Pro Tools 105 1.75” x 6” 90º
http://www.pro-tools.com/diesets.aspx
Condition : Used - Excellent
New : 255+50 Shipping
Asking : 250 Shipped
JD Squared Notchmaster w/ SWAG reacharound
http://www.jd2.com/t-notchercomparison.aspx
http://www.swagoffroad.com/JD2-Notch-Master-Reach-Around_p_49.html
Condition : Used (40 notches) Great condition.
New : ~430 with shipping
Asking : $350 Shipped.
Jeep TJ Factory Cowl
Condition : Used
Asking : $40
