Gathering parts for the build!
SLUMLORD
I have sourced a set of 4 stock jk rubicon wheels and tires to match my jeep and bought the steel for the trailer frame. I will have a limited time in the shop i'm welding it up in, so i need to have all the parts needed to roll it home before i start building. So i have a few questions and any responses would be much appreciated. I will be using yj springs so i was wondering where to get weld on front spring hangers. also, spring perches that would work with yj springs and a 2 3/8" diameter trailer axle and what u bolts would be required. Or, do i just use a square tube axle and drill the spring centers where they're needed. If i use a square tube axle are spring perches even needed? and also where is a good place to find wheel spacers to allow me to use the jk wheels and how thick of a spacer do i need to clear the hub. And one more question. Has anyone used extruded aluminum decking for their trailer. I saw it somewhere and now cant find it. I would describe it like t&g deck boards. Like i said i would buy parts as needed which would make the process easier but i dont have much time to build.And it's my first trailer build so it's a learning experience. I just like to be prepared instead of scratching my head. thanks
SLUMLORD
actually iv'e found rear hangers(shackle end) already. I get catalogs from both of those companies. and now i found front hangers at www.ruffstuffspecialties.com, lots of good stuff there, everyone should check out that company. and i believe yj springs are 2 1/2" wide. but thanks jeepdork, great name.It probably describes a lot of people on here.
JeepDork
Yeah your right cj are 2" front 2.5 rear yj 2.5 front and rear.
lilgription
Ballistic Fabrication is a company I always order from. They have all kinds of spring hangers and custom corner braces etc. They service the offroad buggy world. Awesome to deal with and have fast shipping. Checm-em out
Pikeman
Slumlord- go to Dexter Axle and look up a local retail distributor. Their standard 3500# trailer axle is a 2 3/8 tube with or without electric brakes and they will mount the spring perches where you want them. You will need to know the Hub face to hub face(aka WMS-WMS) measurement and also spring center to Center for the perches. Can be oredered in matching lug pattern. You can also get the 2200# axle but I am not sure tube diameter on that one. www.etrailer.com will have a lot of the other parts you will need from lights to include Ubolt kits.
