roaming knome
Hello,
I have both front and rear complete axles from a 1989 Mitsubishi Montero. Both have LSD however I do not know what the stock gearing is, the stock engine in the vehicle is 3.0L V6 if that helps. They both are in great shape, the only reason i'm selling them is that the Montero is my project vehicle and its getting a solid front axle and I have chosen to use Toyota axles front and rear. I do have the rear trailing arms and brackets that have been carefully removed from the frame, rear coil springs,and trackbar for the rear axle as well for a complete swap or if you want to convert from leafs to coils.
I believe the rear diff is a 9" and the front 8"
I only have pictures of the rear axle but I can take photos of the front upon request. It looks like your typical IFS front diff with CV shafts. Front CV shafts will need to be rebuilt as I tore the boots when removing.
let me know if you would like me to post up any other photos of any of the aforementioned components
I'm asking $150 each and am willing to crate/box and ship anywhere
If you have any question, let me know.
