SlimPickins
Escapee
Hey all,
Forgive me if I've missed it but I searched forums and my factory service manual but I'm not finding a diy/procedure/torque specs to change the auto trans filter in my 1998 Monty. The manual doesn't seem to even list it under the maintenance schedule. I assume it does indeed have one as the WIX kit I purchased says it does indeed fit this model. I drained the fluid using the procedure outlined on 4x4 wire (neutral, remove cooler hose, start engine for 30 sec, remove drain bolt, etc.) but I don't see anything specific to the gen 2.5 regarding filter. I did remove supporting crossmember so that all pan bolts are accessible. My drain bolt says "DII" but based on most recs, I have purchased the Mitsubishi Diamond SP. Are most of you skipping the filter? My Monty has 155k miles, no service records. The fluid is brownish red, doesn't look terrible but I'm baselining all the maintenance.
