billygoats
n00b
When I got my Monty a year and a half ago, one of the first "mods" I did was 6k drop in h4 hi-low hid. Due to the fact they were installed into the factory reflector housing designed for halogen, the light pattern was off, resulting in light spray/bleed. I had to aim them way down to avoid getting flashed, which reduced my useable light!
I finally got the courage and time to put in a bi-xenon retrofit today.
I used a drop-in, no-name bi-xenon 2.5" projector set from amazon. It was about $50 for the pair with shrouds. They are designed to sandwich into your existing h4 hole, requiring no drilling or custom mounting or gluing. They use common d2s hid bulbs. The have a seperate wire for the high beam solenoid. I purchased some d2s 4300k bulbs which should be here later this week. I also got some more headlight sealant which hasn't come yet. Not a big deal since the truck is at the shop getting new head gaskets.
Here are a couple pics of the install.
Oven baking 15 mins at 220f. Just right to pull the lenses off.
That's all for now. Need to wait for the glue, bulbs, and my truck back to proceed.
I'm hoping to have a nice sharp cutoff and better lighting! I'll post an update later this week.
