stioc
Agreed on the de-merits of a body lift which is why I suggested if you do it to not go more than 1" and that would be to simply clear bigger tires- if needed (not needed for 33s on Monteros). I also agree that more suspension travel = good but you're not going to get any more suspension travel with a simple spring lift than before. For that you'll need longer shocks and matched springs...and with that you'll also need to drop the subframe to not screw up the CVs every few hundred miles. The only thing a basic spring lift gets you is higher weight carrying capacity and some rocker clearance, not to say that it's a bad thing, we can almost always use both of these. About the only other thing you can do to gain some additional suspension travel (or more accurately to take full advantage of the existing suspension travel) and increased articulation is by removing the sway bars.
As for the body lean, yeap...but then again the Montero is not a rock crawler. Nathan I think you know this already but your Rubi experience spoiled you a bit with what it could do. You're now with us mere mortals
However, you might find that the Montero is closer to your old LR3 than the Rubi...of course noting that the LR3s are supposed to have very good articulation for an IFS/IRS truck.
