Gen 3.5 front fender removal for antenna repair
Offroadmuch
So I found the three screws just inside the hood for the feneder. Can someone point out the location of ghe others? I need to pull the motorized antenna assembly. Thanks for the help....
I am going to try this in the FSM although it is kind of slow going to find things in there sometimes.
coffeegoat
It's on my list too, apparently just replacing the extendable mast is very easy generally with no part removal required, however, I'd rather go back with a flexible whip so it doesn't break again
Michael Brown
You followed me, so now we're both lost
Remove the wheel and inner fender liner. I did this 2 years ago when I broke the original in an ice storm (low hanging tree branches).
The power unit can be split open after removing the housing screws.
I had found an instruction with pictures before, but cannot find it now.
nwoods
There are also a few bolts in the door jamb of the A piller (typically, not 100% sure about 3rd gen)
Fergie
I came at it from underneath as well.
I disconnected the power, and essentially have a fixed antenna now...easily reversible.
Offroadmuch
Picture from the Mitsu FSM on how to remove a front fender. Finally found this. Just FYI in case anyone else needs this reference.
