2to4wheels
Wondering if any of you have preferences? Want to replace my oldish battery before I need to and was wondering what you guys have been using.
WalMart. 3 year replacement warranty with no pro-ration.
John B.
I'm high maintenance, I went with a yellow top, and when I get my dual battery system finished, I'll probably get another yellow top.
But...that... that is exactly the opposite of what your link shows. The red top is the starting battery, yellow and blue are deep cycle (save the dark grey 34m referenced in the link, which is a marine starting battery).If you intend to run a winch or other accessories that will discharge the batteries you should have went with the M(D34M/D27M,etc) series blue top, it was designed as a dual-purpose starting/deep discharge battery with more reserve, and the yellow top is simply a starting battery that will die much quicker when discharged repeatedly. More info here https://www.optimabatteries.com/en-...ifference-between-yellowtop-bluetop-batteries
so 24 or 35? My truck currently has a 24 but I see they both fit.
