jasonsuperb
I'm planning to do the timing belt on my gen 3 montero with the 3.8 motor and have been trying to gather all the information about what other parts should be replaced while the engine is partially taken apart. I figured having a thread with all this information in it would not only help me to organize the parts necessary but would save someone else the time of searching through various different threads etc.
I do not know everything at this point so hopefully others can chime in on what parts should be replaced and maybe certain parts aren't necessary to replace. For instance if a part doesn't have any history of failing I don't see why you would bother to replace it just because you can.
I also want to have a list of part numbers and best places to get the individual parts or kits.
I will keep this top post updated with any new information given lower down the thread so people won't have to search around as much.
List of things that should definitely be replaced at every timing belt interval (not finalized at this point)
http://mitsubishiparts.net
Timing Belt
Part # MD358549 currently $142
Water Pump ( Is this necessary ?)
Part # MD979171 includes gasket currently $175
Timing Belt Tensioner ( Is this necessary)
Part # MD362861 currently $60
Idler Pulley (2)
Part # MD319022 & MD140071 currently $43 & $40
Crankshaft Pulley Bolt
Part # 1100A141, Washer #MR994412 if still using old dumbbell style currently $12
CRANKSHAFT POSITION SENSOR Montero; 3.8L ( Is this necessary?)
Part # MD357274
CAMSHAFT POSITION SENSOR Montero; 3.8L ( Is this necessary?)
Part # MD360196
Other commonly replaced items at the same time
Valve Cover Gaskets (2)
# MD303148 $23 each
intake manifold gasket
#MR561678 $12
PLENUM GASKET Montero; 3.8L; Upper; Left
Part # MR561581 $14
PLENUM GASKET Montero; 3.8L; Upper; Right
Part # MR561582 $14
PLENUM GASKET Montero; 3.8L; Lower
Part # MR561584 $10
Cam Seal if leaking (2)
# MD372536 $10 each
Spark plug 3.8 LITER
Part # MR984943 $11 each
Plug wire set 3.8 LITER
Part # MN153270 $101
Other sources for parts or kits
Aisin Timing belt kit on amazon
http://www.amazon.com/gp/product/B0...rue&ref_=ox_sc_act_title_1&smid=ATVPDKIKX0DER
Continental Elite GTKWP320H Timing Belt Component Kit (With Water Pump)
http://www.amazon.com/Continental-E...32-194-5-0&sr=1-9&ymm=2003:mitsubishi:montero
advance auto timing belt kit
http://shop.advanceautoparts.com/p/...rans&utm_campaign=shipped&utm_content=general
I should also mention the owners manual recommends to replace the timing belt at 60K, it then says to replace it at 100K if not previously replaced. So what I take from that is it should last 100k, but many might not want to risk that since it is an interference engine. It also doesn't mention when most of the other items need to be replaced, such as the water pump or timing belt tensioner.
Timing Belt
Idler Pulley (2)
Part # MD357274
Part # MD360196
# MD303148 $23 each
#MR561678 $12
Part # MR561581 $14
Part # MR561582 $14
Part # MR561584 $10
# MD372536 $10 each
